Old 03-16-2017, 11:54 AM   #1
luke2220
luke2220's Avatar
Drives: 16 black on black camaro rs
Inexpensive Homemade tool to keep your Camaros undercarriage clean!!
Hi there, Please check out my video that will show you how to make an inexpensive undercarriage washer to keep your Camaro's undercarriage clean from all that road salt and sand! I hope you enjoy it and will try making your own at home
luke2220 is offline   Reply With Quote
Old 03-16-2017, 12:35 PM   #2
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
Your wife is going to murder you if she finds out you used her good towels.
Good how to.
JerTM is offline   Reply With Quote
Old 03-16-2017, 12:42 PM   #3
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
I like it! Been wanting to make one... was thinking I needed little screw in nozzles. Just drilled holes seems to work fine and saves $$$$
maddoggyusa is offline   Reply With Quote
Old 03-16-2017, 12:45 PM   #4
luke2220
luke2220's Avatar
Good how to.
hahah don't worry I used old rags and I'm not married just yet...glad you liked the video
Old 03-16-2017, 12:47 PM   #5
luke2220
luke2220's Avatar
thanks!! yeah def its so cheap and of course if you are able to borrow the cement and the primer from someone all u need is a little and that'll save you most of the cost. try it out and let me know how you make out
Old 03-16-2017, 01:09 PM   #6
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
To get even higher pressure you can tap those holes and install brass nozzles. Works really well.
rontammy0 is offline   Reply With Quote
Old 03-16-2017, 01:15 PM   #7
luke2220
luke2220's Avatar
good idea, I was just keeping it simple to keep the price as low as I can for the video! the pressure is pretty good with this, I tested it out in my backyard and the water was able to shoot about 15-20 feet in the air!
Old 03-16-2017, 01:21 PM   #8
rontammy0
Lol....a sprinkler as well. I did a job at Bombadier in Quebec Canada.They build snowmobiles and atvs. We did a rinse tank for the exhaust going down a closed in conveyer systems. The piping was all PVC piping.....2 inch header with 1 inch branches. We tried what you did and were happy. Then installed the brass fittings...wow what a difference. And they are not expensive at all.....and plastic isnt hard to tap. The brass fiitings just up the pressure. Great idea you have there. I cant remember if we wven tapped it or just screwed the thread fitting in.
Old 03-16-2017, 01:34 PM   #9
luke2220
luke2220's Avatar
cool cool definitely something to think about!
Old 03-16-2017, 01:41 PM   #10
luke2220
luke2220's Avatar
Inexpensive Undercarriage washer for your camaro!!
Check out my video that will show you how to make an inexpensive undercarriage washer! Hope it helps you guys keep that Camaro undercarriage clean
Old 03-16-2017, 01:48 PM   #11
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Size:  44.7 KB....rather drive over this...
Old 03-16-2017, 04:03 PM   #12
Tom And Cheryl
Tom And Cheryl's Avatar
Drives: 2013 SS Convertible, ThumperII
I like it, thanks for sharing
Tom And Cheryl is offline   Reply With Quote
Old 03-16-2017, 04:34 PM   #13
luke2220
luke2220's Avatar
Youre welcome! Im glad you enjoyed it!
Old 03-16-2017, 06:13 PM   #14
Irace16
Irace16's Avatar
Drives: 2010 1SS RS M6
I wonder if you squirted some soap in there before you hook up the hose if the soap would last long enough to do the undercarriage , then rinse...
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
Irace16 is offline   Reply With Quote
car car, car care, clean, cleaning, diy, homemade, inexpensive solution, road salt, undercarriage, undercarriage washer, washer, washing
