![]() Drives: 2010 ABM 2SS Join Date: Jun 2016
Midpipe Question
I just installed my JBA Cat Delete pipe and to prevent a CEL, I am using a "Mini Cat Fix" from Big Daddies Garage. I can't get the connector to fit in between the pipe and the transmission. Has anyone had these problems?
![]() Drives: 2010 2SS/RS Inferno Orange Join Date: Mar 2013
I'm pretty sure Big Daddy makes one that is bent 90 degrees. Maybe give them a call and see if that is an option for your set up.
U.S. Army Retired |
Man, that bites! Is the Camaro your daily driver?
U.S. Army Retired |
#6 |
Instagram: Sangstah
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Agreed. Your best bet is to just harass them until they return your calls/emails and see about exchanging for the 90 degree ones.
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
| Tags |
| 2010 2ss, help needed, jba catless mid pipes |
