Old 03-17-2017, 06:19 PM   #1
kurto777
Drives: 2012 RS V6 2LT- AEF Dynamic, MRT v1
CAI on right?
I made a thread a couple weeks ago and I wanted to ask about the install I did by myself.. Does everything look set and right???? Because I have been experiencing surging going uphills and some weird sounds from it over the past couple of months.. Let me know if you see anything unusual about it, also I need your opinions please. the link is below!
kurto777 is offline   Reply With Quote
Old 03-17-2017, 09:15 PM   #2
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
What brand is that? Why do you have 2 hose clamps by the air box wall, and 1 inside on the filter? Is the box wall supposed to be curved like that?
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 03-17-2017, 09:21 PM   #3
kurto777
Its AFE Dynamic. Bought it off ebay. And the installations told me to put it like that.. why? do you think its wrong?
Old 03-17-2017, 09:23 PM   #4
kurto777
heres the link.
http://www.ebay.com/itm/2012-2013-20...dVVNp-&vxp=mtr
Old 03-17-2017, 09:45 PM   #5
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
Your install appears to be fine from what I can see. The only thing that could probably cause the surging would be something with the MAF sensor... if the intake is indeed causing that to happen. If you only get the surging going uphill, it might be something else. What is the sound you are hearing?
Jazzzed is offline   Reply With Quote
Old 03-18-2017, 08:50 AM   #6
kurto777
The surging and hesitation started happening when I put the cai on... And everytime I get to around 35-45 mph I get this whistle around the engine bay area and it does it for bout 5 seconds then goes away. Or whenever I let my foot off the gas pedal. But as soon as I put it back on it does it again. And also I get this weird sound when going over 60 mph,sounds like something is shaking. Its never happened before the cai install..
Old 03-18-2017, 09:32 AM   #7
kurto777
Since ive added this its also been doing this.. But this only happens when i drive the car and then lets say I go park it and leave it for like 2-3 hours then start it back up and its somewhat between cold and hot (the engine)..
https://youtu.be/2ANurRNDvqE
Old 03-18-2017, 04:04 PM   #8
Jazzzed
Jazzzed's Avatar
Really, there isn't much with the CAI that can cause these issues. If all of your clamps are tight and there are no leaks, then the whistle and the surging must be coming from something else. The engine loping, well I would start with replacing that MAF sensor. Because again, there is nothing else with the CAI that can cause that if you don't have any leaks. Did you say in another thread that you cleaned the MAF during this install? Maybe you damaged it. That is a very delicate sensor. Lastly, the pegging of the meters. I have never seen that. Is that what you are trying to point out in the video, or the loping? The CAI is definately not causing the meter to peg. Thats very weird.
Old 03-18-2017, 09:20 PM   #9
BluedEvil21
BluedEvil21's Avatar
Drives: 2013 Camaro v6 hot wheels edition
To me it looks like you hit the hose on top of the manifold the connection twists on and off. I'd make sure it's not loose...one more question did you happen to take off your throttle body for whatever reason?
Drop a gear and disappear
BluedEvil21 is offline   Reply With Quote
Old 03-19-2017, 01:20 PM   #10
kurto777
No that was at idle. Whenever i turn it back on when driving.
Old 03-19-2017, 01:22 PM   #11
kurto777
I never took off the throttle body during the cai install. I only took it off whenever everything started happening. And whenever it started happening then thats when i cleaned the throttle body but it didnt work.
Old 03-21-2017, 08:24 PM   #12
NilesW
Drives: 2018 2SS vert, Hyper Blue
Is there any chance you put the maf in backwards? I did my cai today and discovered it will fit either way. I've done a bunch in the past years and wasn't paying good attention when I took it out and bolted it on the cai tube. As I was fitting the tube on the engine I had this oh shit moment. A close look will reveal an arrow that points the air flow from filter to intake. I had mine on wrong, but reversed it before going any further. I don't know what effect that might have but thought I'd throw this out.
NilesW is offline   Reply With Quote
Old 03-22-2017, 03:44 PM   #13
kurto777
I took my cai off and the car runs much better now. no problems.. I dont know how a $200 cai would mess with my car
Old 03-22-2017, 06:11 PM   #14
Silent...
Silent...'s Avatar
Drives: 2012 2LT RS White Born: 11/10/11
I'm not sure either. But I went with CAI and I've never regretted it.
*Grey Hockey Stripes; Heritage Grill; GM GFX - Unpainted Argent Gray; GM Dovetail Spoiler; Rivercity Creations custom painted rear bowtie, RS & Taillight Bezels; MRR M017 Graphite Wheels; Nitto NT555 G2; ACS 4Teen Heat Extractor
*RX Catch Can;CAI; MF Exhaust; VMAX CNC Spiral Ported TB; Overkill Stage 1 Supercharger System; Hotchkis Comp Sway Bar Set w/ End Links, Cadillac CTSV 4 Piston Brembos on all corners with SS Black Hat Rotors
Youtube Channel - HPDE Driving Videos https://www.youtube.com/channel/UCpO...8aw6hgX3O1Uh7A
Silent... is offline   Reply With Quote
2012 rs 2lt prolem, cai install problem
