Old 03-18-2017, 09:09 PM   #1
karve
karve's Avatar
Drives: 2015 Z/28 #737, 2014 Ford Raptor
Regular Driving Tire Pressure
There's lots of talk on track tire pressure but what are you guys running on the street or for regular driving? I'm at 34psi cold (this is where it was set from the dealer) and 38psi after they warm up. I received a diagnostic from onstar and they said the tires should be at 32psi.
karve is offline   Reply With Quote
Old 03-18-2017, 09:17 PM   #2
mpsgolf
mpsgolf's Avatar
Drives: 2012 Camaro SS Transformer
I'm interested in this. Used to run 38. Worked well for quite a while. At some point picked up a shimmy at about 65ish which appears somewhat common. After searching for solutions on the forum I went up 5psi to 43 and it helped. It is still below max inflation pressure for my tires so I've been sticking with it for 5-6 months so far.
Mods: trunk subwoofer and amp, LED lighting (fogs, interior, trunk), skip shift eliminator, CAI cold air kit, Vmax ported throttle body, Stainless Works retro chambered cat back, JBA Cat4ward SS ceramic coated headers
Potential Next Mods: Tune, F&R sway bars, rear cradle bushing inserts and trailing arms
mpsgolf is offline   Reply With Quote
Old 03-18-2017, 09:39 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
30-32 cold is perfect. Higher pressures will beat you to death! I consider 34 psi cold too high.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 03-18-2017, 10:37 PM   #4
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
^^^^. This.
Over 35 hot is no bueno.
69L48Z27 is offline   Reply With Quote
Old 03-19-2017, 01:30 AM   #5
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
I agree with Stephen12ZL1. 32psi, I do store it with 35 to 38 psi.
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice..
Candr3535 is offline   Reply With Quote
Old 03-19-2017, 05:06 AM   #6
Snowmanvii
Snowmanvii's Avatar
Drives: 2015 Z/28 #328
Tires pressure has to be checked? LoL... I had mine changed out to nitrogen when I had a valve stem seal go bad. Put them at 32 and have not had a issue again. Guess that has been 5 or 6 months ago. When I change out the rears I will go back to air because I will be adjusting the pressure a lot when I will be racing.
Snowmanvii is offline   Reply With Quote
Old 03-19-2017, 05:31 AM   #7
ElkySS
ElkySS's Avatar
Drives: 2011 Camaro SS M6
door sticker says 36psi cold so that's what I set it to.
2011 Camaro SS LS3/M6
1995 Formula 396 LT4/M6
ElkySS is offline   Reply With Quote
Old 03-19-2017, 10:00 AM   #8
Hunt-man
Drives: 2015 Z28 + Piper Comanche
30 to 32 cold for me as well.
Hunt-man is offline   Reply With Quote
Old 03-19-2017, 10:35 AM   #9
karve
karve's Avatar
I will adjust to 32psi cold...thanks to all for the info.
Old 03-19-2017, 01:48 PM   #10
redcoats1976
weird,its says 36 on my door sticker although it usually ends up at 35 on the DIC.cold,38 hot.onstar says this is ok on the monthly report...
Old 03-19-2017, 03:15 PM   #11
Chulai
Drives: '79 Camaro, '99 Vette, etc
My door placard says 32.
'79 Camaro Z28 Pro Street
'99 Corvette FRC
'12 CTS-V Coupe
'15 Z/28 #990
'21 Dodge Charger Scat Pack Widebody
Chulai is offline   Reply With Quote
Old 03-19-2017, 03:25 PM   #12
mb13
mb13's Avatar
Drives: 2015 Z28 #980
Different wheels and tires from the v6 to z28
mb13 is offline   Reply With Quote
Old 03-20-2017, 09:14 AM   #13
Raven87
C'mon- really?
Raven87's Avatar
Drives: Looking for a ZL1
I have mine at 32 cold.
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD
Raven87 is offline   Reply With Quote
