Old 03-19-2017, 02:40 PM   #1
verboten
Drives: Black
Oil leak near front passenger wheel? Do bushings have oil?
Found a drop of oil on garage floor. Put car up on jacks and found oil coming from front wheel control arm bushing.
Anyone change these before or have a DIY?
verboten is offline   Reply With Quote
Old 03-19-2017, 08:26 PM   #2
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
No oil in there....you can replace the inserts that are in there with solid or delrin from JPSS, but not sure what you have leaking out of there....Just got out from under there or I'd check and see if there is a grease fitting. don't think there is....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 03-19-2017, 08:57 PM   #3
verboten
Drives: Black
It didn't think a camaro had hydraulic bushings, but there is clear oil coming out of somewhere. The bushing just started leaking about a drop every 2 week. It's not coming from anywhere else. Totally dry above and around.
Does anyone know if Z/28 radius arm will fit V6. The arm w/bushing is only $69.
https://www.gmpartsonline.net/oem-pa...A0JnI9OQ%3D%3D
Old 03-19-2017, 09:50 PM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
The motor mounts have fluid in them. Check them out.
More to come.
Black_SS10 is offline   Reply With Quote
Old 03-20-2017, 05:47 AM   #5
KillboyPowerhead
Drives: 2015 Z/22
That is the radius rod bushing and it does indeed have oil in it (sound/vibration dampening). I believe you have to replace the whole bushing + arm combo, or buy an aftermarket bushing and push out the old one (more work, but if you're looking to make an improvement over stock... ).
KillboyPowerhead is offline   Reply With Quote
Old 03-20-2017, 08:26 AM   #6
verboten
Drives: Black
Thank you, the Control arms (Radius) do have oil in it! I thought I was going crazy.
At $69 bucks for arm/bushing, I will put in Z28 Radius arm if fits and doesn't squeak, rattle, etc.
Old 03-20-2017, 12:21 PM   #7
Olddudesrule
Resident nomad
Well, I stand corrected. Guess I can rest, having learned something new today
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
Old 03-20-2017, 04:21 PM   #8
KillboyPowerhead
Drives: 2015 Z/22
The Z28 arm would be an upgrade to the original, although if you're willing to spend a few more bucks you could buy the original arm (or whatever's cheaper) and then get yourself some bushing inserts (such as from JPSS) - these inserts are even bigger/harder than the Z28 ones and thus will provide even more control/stability when accelerating/braking/cornering hard.
Old 03-21-2017, 10:27 AM   #9
verboten
Drives: Black
Can I remove radius arm bolt with wrench or do I need special tool to hold other end?
Sent from my iPhone using TapatalkName:  IMG_0650.jpg
Old 03-21-2017, 11:02 AM   #10
O.F.
O.F.'s Avatar
Drives: 2015 BLK/BLK 2SS/RS MN6
Grab the end of the stud with ?...can't tell, is it square? That's what it's for anyway. Vice grips in a pinch.
O.F. is offline   Reply With Quote
Old 03-21-2017, 11:19 AM   #11
KillboyPowerhead
Drives: 2015 Z/22
Wrenches/ratchet for the inside, where leak is; the outside at the knuckle is a ball-joint and so will need a ball-joint separator tool like a fork which can be rented (or bought) for fairly cheap.
Did you add the pink arrow and dot or is that on the car?
Old 03-21-2017, 11:29 AM   #12
verboten
Drives: Black
hahaha...I added the arrow and dot by mistake. I does kinda a look factory.
Old 03-21-2017, 09:33 PM   #13
Pistolgrppump
Pistolgrppump's Avatar
Drives: 2010 2ss/L99 Rally Yellow
No need for a ball joint tool just take the but off and whack the knuckle with a hammer a few times it will fall out
Sent from my SM-N920P using Tapatalk
Pistolgrppump is offline   Reply With Quote
Old 03-22-2017, 05:35 AM   #14
KillboyPowerhead
Drives: 2015 Z/22
Groovy. Last time I tried to remove a ball-joint it wasn't that easy, but good to know
