03-20-2017, 08:09 PM | #1 |
Trouble removing key from ignition
I have to almost press the brake pedal through the floor to remove key, sometimes it is easy but most of the time it is difficult,any suggestions
04-07-2017, 06:23 AM | #2 |
Drives: 2014 2SS MT, Convertible Join Date: Jun 2015
There is a known issue with somethingt in the automatics, shifter assy related that causes difficulty with key removal, or sometimes key cannot be removed at all.
Steve
2014 2SS MT, Convertible Saint Augustine FL |
04-07-2017, 12:04 PM | #3 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Turn the wheel slightly. Try both directions, it'll come out.
04-15-2017, 03:07 PM | #4 |
Drives: 2017 Camaro 1SS, 2023 Sierra Join Date: Feb 2014
Same issue, 2014 2LT. Key won't release. I end up turning the key back to the on position, shifting in and out of park and trying to take the key out. Sometimes it takes a few tries before it releases.
My car is a lease, and I am not going to be happy if I need to replace the shifter assembly and or get billed back for it. Sadly, this is already a replacement shifter, when I first got the car I had my dealer install the footwell lighting, and they scratched the original shifter bezel. Cost to replace is not cheap, over $200 if I remember. |
04-18-2017, 02:32 PM | #5 |
Drives: 2014 Camaro 1LT RS Join Date: Oct 2014
Same thing happened to my car. Had to take it to the dealership to have the shifter assembly replaced because it wasn't engaging properly and would not allow me to take the key out sometimes because it wouldn't fully engage in the "park" position
mods: 1le brembo swap, cold air inductions intake, GM strut tower brace, elite engineering catch can, borla touring, x-pipe, secondary cat-delete, z28 splitter, z28 spoiler, diode dynamics
04-18-2017, 06:20 PM | #6 |
They didn't cover it under warranty did they? Can I ask how much you were charged if they didn't?
04-20-2017, 02:31 PM | #7 |
It was covered under warranty thankfully
