Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > International Regions > Middle East
Old 03-22-2017, 02:57 AM   #1
mhdfahd
Drives: camaro v6
Camaro Speedometer
hi guys
i need small info rgrding camaro
i bought V6 US
speedometer has max reading of 160 irrespective whether i select kms or miles as units
question is when i choose kms whether the reading shows kmph or it shows mph?
if its kmph whether the max speed in car is 160kmph?
mhdfahd is offline   Reply With Quote
Old 03-22-2017, 03:42 AM   #2
johndm
johndm's Avatar
Drives: 2013 Camaro SS
From the manual,
Unit
Move the thumbwheel up or down to
switch between US or Metric when
the Unit display is active. Press
SET/CLR to confirm the setting.
This will change the displays on the
cluster and DIC to either English
(US) or metric measurements.
johndm is offline   Reply With Quote
Old 03-23-2017, 03:02 AM   #3
mhdfahd
Drives: camaro v6
i can change over easily drom km to miles. while driving at constant speed i changed the units and the speedometer reading dropped by a correct ratio (km/miles=1.6)
but the concern is max speed, is it foing to be max at 160 kmph or the speedometer will not read the speed above 160 kmph
Old 03-23-2017, 08:06 AM   #4
robrocketanski
robrocketanski's Avatar
Drives: ZL1 Convertible Auto
The mechanical needle can only go to what is printed on the cluster which would be 160 because the numbers stay the same between mph and kph. But any other speed indicator like the digital display would show the actual speed well beyond 160 kph
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
robrocketanski is offline   Reply With Quote
