03-22-2017, 09:53 PM | #1 |
Drives: 2011 Camaro SS Summit White Join Date: Sep 2015
Can someone please help? Misfire?
Here is a link to the codes
https://youtu.be/f3dqouei4bo I just removed my whole exhaust and swapped from kooks 1-7/8 headers to tsp 1-7/8x3 headers and from borla atak to corsa 3" zl1. I start my car and I get those codes (check engine, stabilitrak) and it's just running like complete shit. The car was on jack stands for probably s month and a half. I was putting back to stock but decided to keep it. So I got new headers catback, but not intake. I check my plug wires and everything was connected fine. I'm not too sure what's going on here. I drove around my block and it would shift very hard. Thanks!!! |
03-22-2017, 11:26 PM | #2 |
Drives: Miss Con Ception Join Date: Aug 2016
Cracked a spark?
2011 1SS/RS LS3 CGM
03-23-2017, 08:38 AM | #3 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
+1..did you remove the spark plugs when workin on the headers? Very common and easy to fix....good luck
03-23-2017, 02:35 PM | #4 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
Loose plug wire or cracked plug.
03-23-2017, 10:55 PM | #5 |
Drives: 2010 Camaro SS Join Date: Oct 2013
If it sat for a month and a half the battery is probably in need of a good charging.
These cars don't like low battery voltages.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
03-24-2017, 03:29 AM | #6 |
"BEASTM*DE"
+2
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
