Old 03-23-2017, 09:24 AM   #1
UBB
UBB's Avatar
Drives: 2018 ZL1
OEM Ground Effect Pkg Discontinued
So I've been leaning towards adding this to my 2014 2SS. Wanted the the OEM kit as it came painted to match already but it appears they are no longer available.
So, I do like the ACS -T4 splitter and side rockers the problem I'm having is which rear diffuser to go with. I don't like any of the aftermarket ones I've been seeing online. I do have the NPP exhaust FWIW.
Thoughts? Suggestions??
UBB is offline   Reply With Quote
Old 03-23-2017, 10:30 AM   #2
Spec
Drives: 2010 Camaro 1SS LS3
Check out the 3dCarbon set. You keep your existing diffuser, but you add side/rear slats. This is what I'm wearing and it does look similar to the OEM kit in some ways.
Spec is offline   Reply With Quote
Old 03-23-2017, 10:59 AM   #3
UBB
UBB's Avatar
Drives: 2018 ZL1
Will do. Thanks!
Old 03-23-2017, 12:12 PM   #4
zr1chris
zr1chris's Avatar
Drives: 2018 Camaro 1SS/1LE
Damn, something I've been debating on doing...
zr1chris is offline   Reply With Quote
Old 03-23-2017, 12:29 PM   #5
littlewing57
littlewing57's Avatar
Drives: 2013 Camaro RS
Just a vote of confidence on the ACS stuff - it was a great fit right out of the box. I went with the T5 and rockers. You might want to consider the rear bumper side extensions while you're at it. I hadn't considered it until it was too late. Still not positive I'll do it but it's probably better to do them all at the same time if you're having yours painted. Have fun!!
littlewing57 is offline   Reply With Quote
Old 03-23-2017, 12:42 PM   #6
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
you sure it's not available?
What color is your car? Do you have NPP??
Part Number: 22986803 Crystal Red (GBE) for SS and NPP
Part Number: 22986799 Red (G7C) for SS and NPP
Part Number: 22986843 Paint to Match for SS and NPP
looks like you can order these from GM still
maddoggyusa is offline   Reply With Quote
Old 03-23-2017, 12:56 PM   #7
gpskinzhut
gpskinzhut's Avatar
Drives: 2020 Corvette Stingray Z51
They only do '10-'13 last I checked though.
2020 Corvette 2LT Z51
2017 ZL1 A10: (SOLD) ||
2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD)
gpskinzhut is offline   Reply With Quote
Old 03-23-2017, 01:00 PM   #8
zr1chris
zr1chris's Avatar
Ahh, that's where his problem is I'd bet. Pretty sure you are correct, although I would think the side skirts should still fit.
Old 03-23-2017, 01:49 PM   #9
UBB
UBB's Avatar
Drives: 2018 ZL1
Called the # on the website and they said it's a back ordered part and none in stock anywhere.
Old 03-23-2017, 03:50 PM   #10
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
I'd be surprised if the GM ground effects isn't still available. The '10-13 set is still available.
Check out my build thread
Old 03-23-2017, 04:15 PM   #11
UBB
UBB's Avatar
Drives: 2018 ZL1
It isn't. I went down to the dealership and the parts guy told me the same thing. No longer available.
I think I'm going to go with the ACS front splitter and side skirts have them painted locally and leave the ass end as is.
Old 03-23-2017, 04:21 PM   #12
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Spring edition / Z28 rear diffuser would be a nice back end upgrade...
That may actually be what they use for the 14/15 GFX kit in the rear.
Old 03-23-2017, 04:44 PM   #13
UBB
UBB's Avatar
Drives: 2018 ZL1
You wouldn't happen to have the GM part # or link to it would you??
Old 03-23-2017, 06:09 PM   #14
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
That blows! Why would they discontinue it? I wanted to get this for my 2LT but sold it. Looks like once I get my next Camaro I will have to look for one that has them already installed.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is online now   Reply With Quote
