Old 03-23-2017, 12:55 PM   #1
chernmax
I Need a Volunteer!!!
Drives: 2010 Chevy Camaro 2SS/RS
Safety Issue if running 2017 MMR 1LE 11" rear rims
I also sent this to the vendor who mounted and balanced the rear set.
IMO this is an Immediate Safety Issue if selling the 2017 1LE Replica MMR rims. The danger is a result of the placement of the wheel balancing weights on the 11” MMR rear rims with 295 40ZR 20 tires.
By placing the rear balancing weights toward the back part of the rim, you LOWERED the clearance between the rim and the rear brake line causing the rear balance weights to cut into the vehicles rear brake lines, THANK GOD, I decided to do a deep cleaning today and found the hazard! As a result I now have to replace both my rear brake lines since they are both now damaged.
Attached pictures of issue… Anyone else have this setup should immediately check to see if they have the same issue? Especially if the practice is to rear mount the weights to balance the rear rim/tires so I may not be the only one with this immediate problem right now?
They did however mount and balance the front 10” rims with the 275 40ZR 20 toward the front of the rim and the fronts have zero contact issues!!!
chernmax is offline   Reply With Quote
Old 03-23-2017, 05:13 PM   #2
GodWentPunk
GodWentPunk's Avatar
Drives: 2015 2SS White Convertible CE/INDY
Holy crap.... Regardless of the weight, it looks like the line is already pretty close to the rim. Good eyes bro!
joe...
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
GodWentPunk is offline   Reply With Quote
Old 03-23-2017, 08:32 PM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
When doing dynamic balance, you will likely want to put some weights on the inside; just following what the balance machine says.
The problem here is that these rims have the wrong offset/width for your car.
Rock-It Man is offline   Reply With Quote
Old 03-23-2017, 09:50 PM   #4
ddunerider
So-Cal Race team!!
ddunerider's Avatar
Drives: Tahoe LTZ,2010 2SS/M6 Camaro
Send a message via AIM to ddunerider
Yep same problem...and i have 18" wheels
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!!
ddunerider is offline   Reply With Quote
Old 03-24-2017, 08:57 AM   #5
chernmax
Have new steel braided lines going in that will be strapped back.
