Old 03-24-2017, 04:06 PM   #1
Jc_SourPatch
Drives: 2014 2LT Camaro RS
V6 to ss bumper conversion
This conversion is easy if you have all the right parts the v6 lower grill will not fit into the ss lower section. Must get a ss specific lower grill section
Jc_SourPatch is offline   Reply With Quote
Old 04-02-2017, 01:05 PM   #2
EverydayHungry
Drives: 2014 RRM Camaro LT RS
Do you think its possible to get the zl1/z28 bumper to work ? Also had bad is the lineup for the cowl lines?
EverydayHungry is offline   Reply With Quote
Old 04-02-2017, 08:17 PM   #3
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
check out Gary's, he can even match up the cowl lines. Excellent work and color match. What ever you do only use GM parts. http://www.camaro5.com/forums/showth...light=gary+zl1
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 04-02-2017, 10:50 PM   #4
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The ZL1 is only a direct swap for 10's-13's. For the 2014 MY, it will still fit but cost almost 3 times as much since it requires you to also buy new headlights (MSRP is $900 per side), new wiring harness and a couple other things.
Old 04-04-2017, 11:04 PM   #5
Jc_SourPatch
The z/28 and as bumper are the same only difference is the upper grill and just for future reference taking the lower and upper grill off the old bumper is a pain in the rear. The lower grill from a v6 won't fit on a ss/z28 bumper so you would need to order that before hand as the shock absorber attaches the the lower and upper grill making it impossible to use bumper without lower grill
