Old 03-24-2017, 09:28 PM   #1
Ryan63052
Drives: 2012 Camaro 2SS
JPSS is amazing !
Parts list as follows:
Billet Radius Arm Bushings
JPSS 32mm Rear Sway Bar
Z/28 trailing arms
Z/28 toe links
Pegasus solid aluminum sub-frame bushings
When i first started driving my 2012 Camaro SS with these upgrades it completely changes the feel. You can lay into it on corners or even a straight stretch and this thing absolutely handles. The steering is awesome, but the ass end is the best improvement by far. It is a totally different car. Gotta say for the price and how it handles , this is an amazing setup. I wont ask or go anywhere else for suspension questions. I have full bolt ons and a tune with this set up , and i lay into it now on some of the on ramps on here or back roads and this things ****ing sticks and has no roll what so ever ! Can not say enough good things about Pete from JPSS ! Now i wanna do more suspension when i get my cam lol !
Ryan63052 is offline   Reply With Quote
Old 03-24-2017, 10:20 PM   #2
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Stock rims/tires?
Probably the biggest thing to do next would be 1LE shocks/struts.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 03-25-2017, 12:07 AM   #3
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
He does appear to be "The Man"........wish I was on the East Coast...
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 03-25-2017, 03:05 AM   #4
L99CAMA2011
L99CAMA2011's Avatar
Pete has suspension and handling in his blood. His advice has always been top notch.
Old 03-25-2017, 03:41 AM   #5
mdub76
mdub76's Avatar
Drives: 2010 2ss/RS IOM GFX M6
Had all this stuff done about month ago. I actually enjoy driving my car now.
mdub76 is offline   Reply With Quote
Old 03-25-2017, 08:08 AM   #6
Ryan63052
I have MRR Z28 wheels, 20x9 front 20x10rear , Mickey Thompson street comps . Shocks and struts are next for sure !
Old 03-25-2017, 08:28 AM   #7
PostNup
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99
Did mine a couple of weeks ago. Unbelievable difference!!
I also did the castor locks and Pete's aggressive street alignment.
Pete makes them how they should've come come from the factory. I've hit 1.02g so far and I know that there is more in her - I just ran out of corner HAHA. Will hit it faster next time.
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires.
PostNup is offline   Reply With Quote
Old 03-25-2017, 08:09 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Does anyone have the aggressive street spec alignment numbers?
Orange Krush II
Old 03-25-2017, 08:21 PM   #9
PostNup
CAR-DASHIAN
Quickest way... Google my username and JusticePete. In my review, you will see my alignment sheet with the specs.
Old 03-26-2017, 09:25 AM   #10
PostNup
CAR-DASHIAN
Here you go!! Enjoy
Old 05-01-2017, 09:23 PM   #11
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Camaroless for now...RIP "Big SexZ"
Yes they are.....just had Pete's JPSS crew install my moreno motorsports camber plates along with JPSS's caster locks, front radius arm inserts, Z/28 rear upper control arm bushings and their 32MM rear black magic bar with their track alignment.
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
Old 05-01-2017, 09:41 PM   #12
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Why didn't you go with the JPSS camber plates?
AG1LE is offline   Reply With Quote
Old 05-02-2017, 09:47 AM   #13
JusticePete
Drives: Camaro Justice
How did I miss all this love in cyber space?
Thank you all for your kind words. They are much appreciated. Thank you all!
Old 05-02-2017, 11:33 AM   #14
PostNup
CAR-DASHIAN
I've pulled 1.02g so far... Ran out of corner haha.
Local track gas a skid pad, gonna throw her on that shortly.
Will update with results.
Thanks Pete!!
