Old 03-25-2017, 11:16 AM   #1
JWade
JWade's Avatar
Drives: 2014 Camaro SS/RS, L99
Lug nuts for staggered Rohanna
I had a set of RC7, 20x9/10, installed recently. The rear lugs on the 10s are flush with the face of the wheel, but the lugs for the front 9s are inset about a half inch or so, enough that you cant see them standing by the wheel. My understanding is that is how the wheels are designed betweeen the 9s and 10s. Can i simply purchase a longer set of lug nuts for the front to even it out and make the fronts flush with the surface? Any recommendations? Thanks in advance. Need to be the thin diameter type, OEM do not fit.
2014 Camaro SS, L99
MBRP catback, CAI cai, Stainless Power LTs HFCs, tuned by KP Racing, Rohana RC7's, Z28 spoiler.
JWade is offline   Reply With Quote
Old 03-25-2017, 11:45 AM   #2
PK Auto Design
PK Auto Design's Avatar
Drives: 2017 Chevrolet SS 1LE
Thats just how they are because of the backpad brotha. You can get longer lugs upfront just make sure they are tuner lugs.
PK Auto Design is offline   Reply With Quote
Old 03-25-2017, 01:42 PM   #3
JWade
JWade's Avatar
Thanks, yes, i was looking for recommendations on a brand and length of lug nut to use for the fronts. Just tuner extended length 14x1.5mm for the fronts and standard length tuner 14x1.5mm for the rear?
2014 Camaro SS, L99
Old 03-28-2017, 02:45 PM   #4
Outlaw77
Outlaw77's Avatar
Drives: 2018 Charger SRT 392 F8 Green
I have RC7's and they should be about flush in both the front and rear. I think you might have all of the same size lugs. I think the rears should be a bit longer than the fronts.
Outlaw77 is offline   Reply With Quote
Old 03-28-2017, 02:47 PM   #5
PK Auto Design
due to the concave the rear pokes out a bit yes but they should all be about 1.38" or so in length no reason to change them out and have different length fronts and rears.
