Scosche, android stereo. Tpms light on. Help please
Hi, I'm new to this forum. I have a 2013 2ls and I installed
7" android stereo and scosche dash kit. Everything seemed working just fine After a week of driving, the tpms light came on and the reading on the tires keeps switching. Sometimes all tires read nothing and sometimes it shows 1 or three tires only. And sometimes it shows all four tires and the light goes off for a few miles. I contacted scosche and they said to update the firmware. When I tires to do it, it showed that the unit had the most recent firmware. Help please |
![]() Drives: 11 camaro Join Date: Mar 2017
my 2011 ss did the same thing. I had to return it finally. it works in some cars and others it won't.
So you went back to the stock stereo ?
![]() Drives: 2012 IBM 2SS/RS LS3/M6 Join Date: Apr 2015
Same thing happened to me and Scosche send me a new unit. Turned out to be caused by the power cable for a dash cam that I routed above the windshield. If you think it's the Scosche call them and see if they'll send you a new one.
Stainless Power LT Headers, K&N Typhoon CAI, VMAX Ported Throttle Body, Jannetty Tune, Phastek Scoop & Washer Bottle Relocator, VTC
Resonator Delete w/Flowmaster Super 10's, BMR Lowering Springs, Koni Orange Struts, Factory Hurst Short Throw Shifter, Skip Shift Eliminator, DRL & Halo Harness, Window Valet Scosche Kit w/Pioneer AVH-4100NEX, Lloyds Custom Mats, Blue LED Footwell Lighting |
#6 |
![]() Drives: 2017 Camaro 2SS Coupe Join Date: May 2010
I heard too many problems with the Scosche kit so I went Metra and very happy with it
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
I have a Scosche kit and don't have any issues with it, but I did not install it myself.
The only complaint I have with the Scosche kit is that it will partially block visibility of the top 2 gauges on the 4-pack gauges.
#8 |
I did email scosche and I'm waiting for their reply
#9 |
gonzo ss, so it wasn't the scosche unit ?
#10 |
No, it wasn't. I thought it was because the symptoms were the same as others have had from the Scosche. I had added a dash cam and ran the power cord along the top of the windshield. It was what interfered with the tpms and key fob signals.
I mentioned it in case you have done the same for a radar detector or something. One thing you can do that I didn't is unplug power to the Scosche and see if the sensors show up. You have to drive, but they should show up right away.
#11 |
Ok I will try that
| Tags |
| android head unit, scosche, tpms |
