Old 10-24-2009, 07:25 PM   #1
JJ2010
Drives: 2010 Camaro SS
MagnaCharger and Water in Exhaust.......
I have noticed since I have had the TVS-2300,Cam,and CAI installed my car has lot's of water in the exhaust.I have worked in years past with Air compressors and there is always problems with water in a air system.That is the reason for air dryers,filters,etc.Is this normal and will it cause any problems down the road?I have noticed it changes depending on the temp and humidity.I'm not loosing any water it just seems like condensation.
JJ2010 is offline   Reply With Quote
Old 10-25-2009, 09:56 AM   #2
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
I'm seeing alot of this as well.
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 10-25-2009, 11:42 AM   #3
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Water is a byproduct of combustion...when you increase the amount of air forced into an internal combustion engine, the byproduct of that would be increased H20.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 10-25-2009, 11:44 AM   #4
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
That is what I am thinking also.
ZZcamaro is offline   Reply With Quote
Old 10-25-2009, 02:33 PM   #5
JJ2010
Thanks guys.....
Old 10-25-2009, 02:53 PM   #6
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
Another good reason to go with a stainless steel exhaust. Corsa, Borla and Magna Flow are just a few, pick a sound and make sure of stainless construction.
When air gets compressed you also concentrate the water in it. As it exits the engine as a hot gas and hits the cooling efects of the exhaust system it condenses back out thus driping occurs. Should'nt ever hurt anything in the engine and also happens in naturally aspirated engines to a lesser extent. It will however eat up mild steel exhaust over time.
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
