Old 03-29-2017, 12:04 PM   #1
imaSSnake
'Maro
imaSSnake's Avatar
Drives: 2015 SS 6.2L Auto 2SS
Will these fit?
2015 Camaro 2ss. I'm sure it depends on tire size, can I fit these wheels with a tire combo that won't rub?
How about flush with fenders?
I'm a newb at offset and such. Any input is appreciated thanks!!
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
imaSSnake is offline   Reply With Quote
Old 03-29-2017, 12:13 PM   #2
The camaro show
The camaro show's Avatar
Drives: 2015 camaro 2lt
should work bit wide for front then normaly
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5
Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85.
The camaro show is offline   Reply With Quote
Old 03-29-2017, 12:54 PM   #3
PK Auto Design
PK Auto Design's Avatar
Drives: 2017 Chevrolet SS 1LE
Yes they can, have a shorty stem applied upfront and worst case a 5 mm spacer upfront
PK Auto Design is offline   Reply With Quote
Old 03-29-2017, 01:14 PM   #4
PROZ11
PROZ11's Avatar
Drives: 2012 RS/2SS, 69 ProStreet Camaro
A 10.5 +35 with a 5mm spacer will sit flush up front?
PROZ11 is offline   Reply With Quote
Old 03-29-2017, 03:00 PM   #5
PK Auto Design
Not dead flush but close
Old 03-29-2017, 05:06 PM   #6
imaSSnake
'Maro
imaSSnake's Avatar
Thank you guys, so can you recommend a tire size that works?
These are almost too wide I'm thinking for me, and kinda too much right now budget wise. But I'm trying to barter a bit with the guy so who knows. I really think those would look good
Offset is going to look better than this then?
Old 03-29-2017, 05:07 PM   #7
imaSSnake
'Maro
imaSSnake's Avatar
Thanks guys
Old 03-30-2017, 09:44 AM   #8
Hixson
Hixson's Avatar
Drives: 2015 Camaro 1SS L99
Lots of options for tires on 20x10.5 I run 275/40/20 currently and they are fine - but IF youre buying tires I would look at maybe 285-305 and anywhere from 40-30. Ill probably buy 305/35 when its time to buy tires again so as long as the price doesn't kill me. 285/40 would be a good option for you if your on budget probably.
Hixson is offline   Reply With Quote
Old 03-30-2017, 09:59 AM   #9
imaSSnake
'Maro
imaSSnake's Avatar
Thanks very much, I appreciate the knowledge
Old 03-30-2017, 11:12 AM   #10
PK Auto Design
275/40/20 is the bang for the buck size.
Old 03-30-2017, 11:51 AM   #11
Maiden69
Maiden69's Avatar
Drives: 2020 Orange Crush 1SS/1LE
The rear will be almost identical to the ZL1, but the front will be a close call, I am running 285/35/20 up front with 10x35, and it is close to the strut. You can run that set up with a 5mm spacer, and still run the 285's square.
Maiden69 is offline   Reply With Quote
Old 03-30-2017, 12:29 PM   #12
imaSSnake
'Maro
imaSSnake's Avatar
Appreciate that, thanks for the response
How would a square setup in 285 affect the handling? As in oversteer understeer balance...
Appreciate your input
Old 03-31-2017, 01:32 PM   #13
PK Auto Design
your welcome.
