Old 03-31-2017, 01:00 PM   #1
sdmaro
Drives: 2011 LS Camaro
70k maintenance
My 2011 is reaching 70k miles... has been great with no outstanding issues. Regular oil changes every 3-5k miles and that's about it. Besides GM's generic maintenance plan, anything I should check for? If anyone can chime in on the items below as well:
- Brakes are requiring more force (so I'm thinking great time for brembo upgrade)
- Rear diff fluid
- Brake fluid
- Coolant
- Timing chain
- Spark plugs
- Any suspension?
Exhaust: Magnaflow catback/x-pipe, Injen SRI, BBK Headers w/ no cats
Suspension: BC BR Coilovers
Cosmetics: ZL1 front conversion, AAC plasma afterburners 2.0, GFX rear,
Interior: AAC red footwells, ZL1 shifter boot/knob, suede center console
sdmaro is offline   Reply With Quote
Old 03-31-2017, 01:04 PM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
What timing belt? It's a chain.
Diff fluid? Not if it's an automatic with an open diff.
None of the others are required, but changing the coolant and brake fluid are good prevention.
Rock-It Man is offline   Reply With Quote
Old 03-31-2017, 01:04 PM   #3
Coleroad
Coleroad's Avatar
Drives: 13 Camaro
I change the differential fluid in all my vehicles every other oil change. It's cheap , easy, and I've never had a differential problem including a leaking seal.. If you haven't changed the coolant, it's over due.
Coleroad is offline   Reply With Quote
Old 03-31-2017, 04:05 PM   #4
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
if you have auto... good time to drain and fill trans, replace filter
maddoggyusa is offline   Reply With Quote
Old 04-02-2017, 11:45 AM   #5
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
A manual intake valve cleaning will amaze you with the results, and NOT an engine running seafoam or similar. Search here for dyno sheets and before and after results.
Elite Engineering is offline   Reply With Quote
70k, maintenance
