Old 03-31-2017, 10:28 PM   #1
rangomr
rangomr's Avatar
Drives: Oracle Camaro has all the bells &
Replaced Throttle Body/Did not help??
Before I took my car in to my mechanic, it had been going on for 4-5 weeks off and on. Suddenly a reading would come up saying "Reduced Engine Power" & I had NO power with my foot to the floor. I would pull over and shut the car down and it would apparently reboot itself.
rangomr is offline   Reply With Quote
Old 03-31-2017, 11:45 PM   #2
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
Yeah, the reduced power mode can happen due to a variety of reasons. The throttle body was a bit of a stab in the dark. How old is your battery, and did you get a check engine light?
Jazzzed is offline   Reply With Quote
Old 04-01-2017, 06:54 AM   #3
rangomr
rangomr's Avatar
Yes I had a check engine light come on since the car would lose power and it would die down to 20 mph until I shut car off. This car has two batttery because of all the led lights, etc & a tripper charger. Both are just a year old.
Old 04-01-2017, 07:09 AM   #4
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
What is the CEL code you're getting? Could be the gas/accelerator pedal sensor which sends the signal to the TB that's gone bad. Very common.
camguynj is offline   Reply With Quote
Old 04-01-2017, 09:54 AM   #5
bleavens1962
Drives: 2014 1LS Camaro
Do you have a Vitesse Throttle Controller by chance ? If so, I would remove it and see how the car runs...Personal experience for me was that the VTC did not work well with my car
bleavens1962 is offline   Reply With Quote
Old 04-01-2017, 10:30 AM   #6
rangomr
rangomr's Avatar
I appreciate your newest comments. Im writing them down to show my mechanic on Monday since I left the car at his shop. He should figure it out since he's also the crew chief on a local guy that races at the track here in South Boston, Va.
Old 04-02-2017, 01:23 AM   #7
BluedEvil21
BluedEvil21's Avatar
Drives: 2013 Camaro v6 hot wheels edition
Yes if you have any throttle controller I'd unplug and reinstall... I personally had this happen to me... after a snug reconnect I haven't had a problem since
Drop a gear and disappear
BluedEvil21 is offline   Reply With Quote
Old 04-16-2017, 11:24 PM   #8
rangomr
rangomr's Avatar
The problem was in the Turbo picking up crap in the waste-gate,etc including into the pipes. I'm learning more & more about my car. Amen
