Old 04-01-2017, 12:18 AM   #1
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
0W-20/40 Oil
Has anyone used a 0W-20/40 oil in their car yet? What are the pros-cons.
The Dodge Hellcat spec is 0W-40 thoughts or opinions???
Orange Krush II
Old 04-01-2017, 12:41 AM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
0wXX is going to be the new 5wXX oil, in my opinion.
Much better pour at low temperatures leads to less wear on startup.
The BMW dealership I work at has switched over their bulk tank from 5w30 to 0w30.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 04-02-2017, 02:50 PM   #3
07-SRT
07-SRT's Avatar
Drives: 2022 Camaro SS 1LE
I use mobil1 0w-40 due to the zddp content but I also uave a high pressure/volume Melling oil pump
2022 Camaro SS 1LE
07-SRT is offline   Reply With Quote
Old 04-02-2017, 09:32 PM   #4
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
0W is too thin for a car like Sledge, that never sees winter, and anything remotely temperatures period.
I do however use, a 0/30 in my daily driven, 4 season car .
There was a thread on here a few years back, where there was an oil viscosity debate, and I
pointed out how ludicrous the discussion was, because you had one dude from Alaska, one from Africa, one from Arizona, New-York....and they were attempting to recommend a proper viscosity range to each other, .
Camaro Dude is offline   Reply With Quote
Old 04-03-2017, 07:48 AM   #5
07-SRT
07-SRT's Avatar
0W-40 is thicker than 5w-30 at high temps
2022 Camaro SS 1LE
Old 04-03-2017, 10:48 AM   #6
Camaro Dude
Drives: ‘13 1LE
All things being being equal, and generally speaking, yes.
But just like tire sizes, there are variations to the theme amongst the different manufacturers.
Example, the "made in Germany" Castrol 0w/30 (which is btw a group lV oil), has been proven time and time again, to be one of the heaviest 30 weight oils out there, when at normal operating temperature, including when compared to the M1 0W/40. That particular GC 30 weight, acts more like a 40 weight!
An other example, Redline 10w/40 group V oil, would act like dino oil 15w/50 and vs even many other group lll 50 weights. A 15w/50 redline group V is thick at temp!!
But yeah, generally speaking, apples vs apples, you are correct
Food for thought.
Old 04-26-2017, 11:16 PM   #7
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
So with all the above being said how would a 0w-xx work in a daily driver / ocassional track car???
Orange Krush II
Old 04-27-2017, 12:13 AM   #8
Camaro Dude
Drives: ‘13 1LE
xx? You mean like a 20 in an already inherited hot running LS3 after a few laps on the track?
Hell no!
A 30, you are back to business, but choose your poison wisely amongst the different variations of 0W-30 out there, as per example above..
Like I wrote before, 2 or more identical (on marketing paper specs) 225 width tires, are not always 225mm width, when you compare different manufacturers side to side. Some 215's, 225's are almost as wide if as wide, as 235/xx/xx's. Precisely why it's wise to read the real spec sheet, and not the front marketing cover specs. Same analogy applies to some oils.
There is enough to worry about, when comparing same cover spec'd, 5W/30's, 10W/30's, etc amongst one an other. Why complicate things even more?
0W/20, its just deviating too far off the spectrum dude.
Old 04-27-2017, 12:39 AM   #9
shibbs
Captain Gingerbeard
shibbs's Avatar
GENERALLY, a 0w40 oil vs a 5w40 vs a 10w40 oil should all be the "same" at operating temperature. You'll be fine.
Old 04-27-2017, 04:17 AM   #10
BallerMaro13
Drives: 2013 ZL1 M6 Black/Black
I used to run Mobil-1 0w-40 in my LS2 TBSS for close to 5 years before I sold it. Never an issue and I daily drove that thing in every type of weather and climate you can think of on the east coast.
BallerMaro13 is offline   Reply With Quote
Old 04-27-2017, 10:34 AM   #11
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Agree. I have run the M1 0w-40 in my last Z, and there were not issues. You'll be fine, and the engine will too.... Oil threads bring out all the arm chair quarterbacks, and I'm one of them. That said, I wouldn't run a 20w in the LS3, but have no issues at all running a 40w.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 04-27-2017, 04:28 PM   #12
L99CAMA2011
L99CAMA2011's Avatar
Ls3 can upgraded with no cats I would recommend Driven HR4 oil. Car runs way better and more stable oil pressure than M1 0W-40. I am at 132,000 miles on my can upgraded LS3 installed at 78,000 miles. Yup 54,000 on a cam job. There's more to oil than the right weight. Driven oils reduce fuel in oil contamination way better than other oils I've used.
Old 04-27-2017, 05:01 PM   #13
Russell James
Russell James's Avatar
Yeah, that HR4 is good stuff.
The only time Chevy recommends a 0 weight oil is in temps below -20F. In summer temps I would see no reason for it. That HR4 10w30 I think is a wise choice for a hot rodded LS motor.
If I ever move to Alaska, i'll be looking hard at those 0 weight oils. Not.
Old 04-27-2017, 05:51 PM   #14
L99CAMA2011
My engine runs way cleaner and stronger with Driven oils than any other. I would even recommend their oils if you don't run a catch can.
