![]() Drives: 2013 Camaro ZL1 Join Date: Sep 2013
Trouble with Long Tube Header Install
Hey guys,
Installed the headers today and everything went fine, but when I loaded my tune up and started to drive the car whenever I was on the highway and trying to give the car gas it started to like surge and struggle to accelerate? Whenever I try and floor the vehicle the car doesn't want to accelerate and struggles in the power band. Its kind of hard to explain. I loaded the stock tune back in and the car is still doing it and I unhooked the battery for 30 minutes. Any idea on what it could be? Also the stability control said it needed to be serviced twice. Very odd. **OUTCOME** Alright guys, I picked it up from the dealership about an hour ago. They plugged their scanner up to the OBII port and found out the car was misfiring on cylinder #3. They pulled the plug and noticed it had a small fracture in it causing the misfire. They put a new spark plug in and the car runs and drives like normal! We must have accidentally hit it when installing or removing the headers, glad this is finally resolved and it was nothing serious. Thank you to everyone for the help!
2013 Yellow Camaro ZL1
Purchased: (9/24/16) 5% Tint All Around 45% Tint on Windshield Roto-Fab Cold Air Intake Oracle Afterburner Tail Lights Oracle LED Sidemarkers RDP Tune TSP Long Tube Headers Forza Componenti 3-Way Exhaust Controller ZL1 Addons Wicker Bill Last edited by BossRS4; 04-03-2017 at 05:53 PM. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Loose ground wire. Are you sure you didn't remove the engine ground strap and forget to tighten it well when finishing up install. Only other wires to touch would have been the O2's. Check all your wires.
![]() Drives: 2013 zl1 Join Date: Jun 2015
check to make sure the the spark plug wires are on if they are check to see if one of the spark plugs are broken
675RWHP 622RWTQ Jannetty Tuned
10.76 @ 131.6 1.6 0-60" |
#4 | |
I feel like its something simple that I am missing and I dont know what it could be. Its driving me nuts.
Purchased: (9/24/16) 5% Tint All Around 45% Tint on Windshield Roto-Fab Cold Air Intake Oracle Afterburner Tail Lights Oracle LED Sidemarkers RDP Tune TSP Long Tube Headers Forza Componenti 3-Way Exhaust Controller ZL1 Addons Wicker Bill |
#5 | |
The odd part is I have no engine light on at all. On thing I have seen twice is the stability control service light come it
#6 |
KaBoom1701
Who tuned it?
Mods:
#7 |
![]() Drives: 2012 ZL1 Automatic Join Date: Apr 2011
...In for the Solution...
2012 Chevrolet ZL1
Automatic |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 1SS 1LE Vivid Orange Join Date: Mar 2011
Did you remove the spark plugs when you installed the headers? If not, you have cracked a spark plug. Or two.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
#9 |
![]() ![]() ![]() ![]() ![]() Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
#10 |
Steve from RDP, I put the car back to stock and its still doing it. I actually called Steve yesterday and he was very helpful.
#11 | |
Still no engine light for the misfire or anything.
#12 | |
Drives: Fast Join Date: Mar 2015
#13 |
Car is currently at the dealership, I took my service rep for a ride and showed him the issue. He thinks the same thing as us, something wrong with the plug wires or spark plugs which is causing the stability track to turn on and act weird.
When I was taking him for a ride the car did not always "surge" or prevent it from accelerating. It did it 3 out of the 5 times I got on it. My supercharger also needs to be replaced again so he is going to take care of that for me too. I will keep this thread updated. Wish me luck!
#14 |
I think a spark plug is cracked or something. I checked them visually but did not pull them out.
Some of the things I have read/researched are saying that when engines misfire it can cause the stability control to act up.
