Nutcase
Drives: "Black Beauty" 2015 1lt in black Join Date: Jul 2016
fuel milage, aerodynamics and top speed
I have a slow by Camaro standards almost stock 1lt Camaro. I use this thing for commuting mostly (its my only car and I drive over 100 miles every day) I love the comfort and smooth ride (I do have afe pfadt springs, zl1 swaybars, an intake, SS mufflers and 20x10.5 wheels all around). I'm looking for subtle ways to make it cut through the air better without changing any of my current mods. the hope is twofold: one is better economy and two when I do play (at a track of course) more top end (I know there is a speed limiter at 120 or so but the soon to be tune will fix that). right now I'm focusing on number one (economy) I'm currently averaging with mostly highway driving right around 30mpg. I want more.
I have purchased the ZL1/ Z28 engine bay pan and will be installing that soon. but I don't know what to do next. a rear diffuser? a splitter extension? more covers for the belly? |
![]() Drives: 2014 Convertible LS3 Join Date: Apr 2015
Do you have the ('14, '15) hood extractor? That helps reduce lift at speed. My guess is it also helps with drag by reducing pressure under the hood with the engine pan.
![]() Drives: 2011 2SS/RS Convertible Join Date: Jan 2017
I believe that some of those handheld tuners like Diablo Sport, Bullydog, etc. come with a couple different tunes(performance, economy, etc.) and one of them is for economy/increased MPG. You might lose some performance but what's nice about those handheld plug-in tuners is that with the push of a couple buttons you can go from an economy mode to a performance mode.
Richard Partlow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Miss Con Ception Join Date: Aug 2016
Don't go all weird on us. 30MPG in a 3800 lb. brick is as about as good as you are going to get.
If you want more MPGs in everyday driving ditch the fat tires. That will mean less rolling resistance and easier to spool up than any aero in everyday driving. A belly pan? Spending dollars to donuts.
2011 1SS/RS LS3 CGM
#5 | |
"BEASTM*DE"
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
#6 |
Nutcase
Thanks for the input guys. I'm planning on a tune shortly since my factory warrantee has run out. as far as a 3800lb brick getting 30 mpg hey 2 or 3 more would be nice and if a tune can do that I'm game. To be honest having this much power and still turning 30mpg is amazing to me.
#7 |
#8 |
Nutcase
I thought gm was 5/50... hmmm.... oh well.... I bought it used with some balance on it I never bothered to check how much.
by June my one year anniversary with the car I estimate it will have 65,000 miles on it |
#9 |
You can go to my.chevrolet.com and create an account using your VIN. If you have warranty left, it will show.
#10 |
![]() ![]() ![]() ![]() Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
Swap out rear gear for something smaller. Will put you at lower RPMs at highway speeds. Car will get off the line a little slower however. Alternatively, at your next tire change, move to a taller overall tire (same effect, will let the engine turn less RPM at the same speed).
For an instant 1 to 2 mpg improvement, bump air pressure up in your tires to 40 PSI. Less rolling resistance. If you're already at 36ish, you won't see much of a difference, but if you're closer to 30 PSI now, you'll see a pretty substantial difference including increased tread life, reduced tram-lining, improved stability under threshold braking, and better protection against potholes.
My thoughts on some things:
#11 | |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
I'm doing mine when the weather gets & stays warmer (52,000 mi)
Don M
Supercharged LGX + 6 speed manual = FUN!! |
#12 |
Nutcase
51psi in each tire, light foot and fresh low ethanol fuel = 32.4 mpg. i do drive the speed limit on the road. I'm saving gas so I can afford to spend it racing on the weekend.
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Seems to me if you are counting pennies, you are in over your head.
#14 |
376 cubic inches of fun
If you want more top end acceleration, get rid of those 20x10.5 bricks you call wheels.
