04-06-2017, 01:41 PM | #1 |
What's wrong with my 1LE
So I recently had a BTR stage 4 cam installed with all the supporting valve train mods and what not. I also have stainless works 1 7/8 catless longtubes, npp, CAI, scoop, and a vmax ptb. There is a drivability issues I've been having and can't seem to figure it out. Under low rpm the car will hesitate, backfire then go. I can't seem to replicate it every time but it still happens quite often and is much worse when cold. Not sure if it's a bad afr, spark plugs or what but it is definitely not normal. I was hoping to get some opinions on what it could possibly be because I have no clue.
2020 BMW X3M Competition
2021 Yamaha MT09 2015 C7 Z06 2015 BMW M3 2015 Camaro SS 1LE Last edited by Lambo850; 05-19-2017 at 11:31 PM. |
04-06-2017, 04:09 PM | #2 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
You didn't mention anything about the tune. Usually the things you describe are tune issues.
What do you have for a tune? Sent from my SM-G935V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
04-06-2017, 05:48 PM | #3 |
Drives: 2013 ZL1 Black Join Date: Aug 2013
Have you checked your MAF to see if you have a strong or weak one?
Sent from my SM-T713 using Tapatalk
2013 ZL1 (purchased 3/2017 with 5k miles) - Black/Auto/Nav/Sunroof/Rotofab CAI/RDP tuned/1 7/8" LT Speed Engineering Headers w/TSP HF Cats/NPP with 3-way control switch/HD-Link
Previous Camaro (sold 11/2015): 2012 2SS - Auto/RS/Black/Sunroof/MyLink Nav/SP 1 7/8" LT Headers w/HF Cats/Hybrid SW Retro Catback w/Borla Pro XS Mufflers/ADM Dyno Tune/C.A.I. CAI/Vmax Spiral Ported Throttle Body/APEX Catch Can/275x4 Squared Wheel Setup/Custom Fit Full Size Spare/Ceramic Tint Replaced with 2013 Black Dodge Charger SRT8 |
04-07-2017, 11:06 PM | #4 |
Drives: ‘13 1LE Join Date: Jul 2013
I wouldn't drive it anymore until a datalog run was done at light throttle acceleration.
05-03-2017, 09:14 PM | #5 |
I figured out the backfiring! One of my spark plugs was not firing properly. I swapped it out and everything is running perfectly now.
2021 Yamaha MT09 2015 C7 Z06 2015 BMW M3 2015 Camaro SS 1LE Last edited by Lambo850; 05-19-2017 at 11:30 PM. |
05-04-2017, 08:09 AM | #6 |
Mine does that too after my BTR stage 3 install. I have the NPP, CAI Inc CAI, Kooks LT and catless too. Mine does the same thing, sputters/stutters? kind of between 2000-3000 RPM and in usually 3rd or 4th gear feels hesitant and backfires upon acceleration. I am bringing it to my tuner this saturday to do some data logging and see whats going on.
I will tell you what happens and what he says unless you guys have an answer for it, or if its normal.
09-21-2017, 10:02 PM | #7 | |
ALWAYS-N-BOOST
2012 1LS M6 Black-Sold 2013 2LT M6 BluRay- Sold 2015 1SS 1LE M6 Black-Sold 2021 ZLE A10 Riverside Blue - Awaiting Arrival 01/10 |
09-22-2017, 11:19 AM | #8 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
If any tuner claims it's normal, better find a new tuner quickly.
> 2021 Camaro ZL1 1LE A10 - power upgrades in the initial design phase > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
09-23-2017, 07:31 PM | #9 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
X2... definitely not normal x or acceptable for that matter.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
