Old 10-25-2009, 08:56 PM   #1
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
ReRoute of Heater hoses w/ pics
Well I finally decided to reroute my heater hoses. I mean how great a design is to have hot coolant hoses laying on your intake manifold and an engine cover thats insulated over top of the hoses retaining serious heat, transfering said heat into the intake manifold is definetly not good for power. I did take the insulation off the underside of the cover but felt that was not enough. Also it looks like crap if you take off your engine cover.
So I decided to figure a way to do this and I was going to get some 90 degree brass fittings and universal hose, put 2 90`s back by the firewall and put 2 at the frame rail to send the hose back to the t stat housing. Instead after talking to Sack Rat 2SS he found 5/8 hoses at autozone that had 90`s on one end premolded into them. These are perfect for the job. I used the 90`s at the firewall and routed the hoses behind the heatshield and under the ABS perch then back to the t stat housing. This worked great w/ a little trimming. I also cut a section of the factory hose insulation (not pictured took pic before installing it) and secured it w/ zip ties in the back as the edge of the hose touched the edge of the rear coil pack. Probably would be fine but I just wanted to be sure it wouldn`t rub through. I used screw type clamps and lets just say it is a pita to get the factory squeeze style clamps off the heater core in the back, not to mention getting the hoses that are what felt like glued to the outlets off was an amazingly hard task for something so simple. I beleive like the ford truck comercial holding the entire truck up by one bed bolt i could have hung by the heater hose w/ no clamp and it would have never came off..Lol.. I did remove the rear coil pack for access. Also of note is one of the outlets is 3/4 at the firewall but w/ a little lube the 5/8 hose will slide over it. the screw clamps i used on the rear connections at the core were installed w/ a small 1/4 drive ratchet w/ a 8 mm socket. At the time I also installed a 160 t stat since I was going to lose coolant anyway.
Here are the pics:
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 10-25-2009, 09:16 PM   #2
rex113
rex113's Avatar
Drives: 2010 2ss silver/cyb
Nice job,it never made sense to me why GM sandwiched those heater hoses between the intake and engine cover.
rex113 is offline   Reply With Quote
Old 10-25-2009, 10:08 PM   #3
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
what was the part # for the hose?
Old 10-25-2009, 10:14 PM   #4
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
GMRULZ even thew me and you do not see eye to eye on the CAI that dos not mean i can not let you know that is a nice job. Wow nice job and i hope you may have a DYI on how it was done as i think that a lot of members will do the same on there car, Thanks for the look.
Old 10-26-2009, 09:49 AM   #5
GMRULZ
GMRULZ's Avatar
Camaro1,
The hoses came from autozone and were part number 4106. They cost me 12 bucks each, plus 4 clamps.
2SSRS,
Hey no problem on the eye to eye thing, everybody can`t always be right...Lol.. Not to mention I don`t take it personally everybody has an opinion, and if you are right on the intake I`ll be the first to admit it, but like I said, I want to see same day, same dyno, sae corrected numbers. Give me that and 30rwhp peak no tuning, and I will sing the praises my brother...
I do try to do things slow and deliberate and make things aestheticly pleasing as well as functional (performance enhancing) vice tearing the car up just to make it faster. Been there, done that, older now, and a little wiser...
Rex,
Thanks
Old 10-26-2009, 09:55 AM   #6
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
Very Nice Job!!!!
2010 2-Tone is offline   Reply With Quote
Old 10-26-2009, 10:15 AM   #7
camaro1
camaro1's Avatar
great job, im going to work on the hoses tonight if my local autozone has the hoses in stock.
Old 10-26-2009, 06:17 PM   #8
camaro1
camaro1's Avatar
thanks, autozone had 2 of them in stock, just finished mine. i kept the factory clamps they came off easy for me. i sliced the hoses with a razor blade to get them off the heater core. wow does this look better!
Old 10-26-2009, 06:23 PM   #9
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
Looks so much better. The hose part number you gave is for a 5/8 inch hose. BTW, did you find a 3/4 inch hose fitting at the water pump just like the one at the firewall? Glad it worked out for you.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 10-26-2009, 06:28 PM   #10
camaro1
camaro1's Avatar
i just used a little lube and the hose slid right on the heater core and water pump fittings
Old 10-26-2009, 07:05 PM   #11
2SSRS@Gen5diy
Thanks for the info got the parts and will do it on Wednesday.
Old 10-26-2009, 09:31 PM   #12
GMRULZ
GMRULZ's Avatar
No problem guys, glad Sack Rat and I could help.
Lube works great..
I guess if you have the right tool for those compression clamps they come off fine. A pair of pliers is very hard to use back there...:(.. So where do you buy said compression clamp puller?
Old 10-26-2009, 10:07 PM   #13
camaro1
camaro1's Avatar
i used a standard pair of pliers
Old 10-26-2009, 11:25 PM   #14
kelleyperformance
kelleyperformance's Avatar
Drives: DD- 15' Chevy SS Sedan
Lube works great..
mine are matco, but ive seen them in any major tool brand.... snap on, mac, craftsman, etc etc
kelleyperformance is offline   Reply With Quote
Pics of the Classic Camaro Unveiling DFWSS USA - Texas 29 05-09-2009 10:44 AM
Seen a RED JEWEL TINTCOAT (RJT) CTF in person...and talked to the GM worker...(pics). DETROIT2010Camaro Camaro Photos | Spyshots | Video | Media Gallery 25 04-28-2009 01:20 AM
Finally got to see one in person!!!!!! with pics Evotion Camaro Photos | Spyshots | Video | Media Gallery 36 04-24-2009 01:02 PM
Thank God For Member: bjschubert And His IOM SS/RS Pics! CoolestCamaro873 Camaro Price | Ordering | Tracking | Dealers Discussions 8 04-14-2009 03:34 PM
Pics of my Vegas trip this weekend (pics of a real nice 60's Camaro) Mindz Camaro Photos | Spyshots | Video | Media Gallery 16 01-17-2008 01:29 AM
