Old 04-07-2017, 11:30 AM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
Re-Installing OEM Washer Resevoir
Hey there, I am reinstalling the OEM washer bottle. However, I can't find the bolts used to attached it.
Does anyone know the size of those bolts?
Thanks,
John
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 04-09-2017, 08:45 PM   #2
JohnZ
JohnZ's Avatar
I found the bolt size. If anyone else needs to know, it is M8x1.25x28.5
However, I used M8x1.25x30 and it fit just fine.
