Drives: 2018 ZL1 1LE Join Date: Jun 2012
Ice Mode in autocross help
Searched and didn't really see anything, but getting back into the autocross season reminds me I need to address my ice mode issue, talking with some of our corvette guys it sounds like a swap to a more aggressive front brake pad would help, so i'm not so much asking what pad to install but more so is anyone else fixing ice mode issues with more aggressive pads, it seems to only happen when going from full throttle to HEAVY brake in a very short time and normally in a straight line. Any help would be great.
![]() Drives: 2013 1le 2ss rs black Join Date: Jun 2016
I'm in the same boat,full power then late brake and ice mode I plow cones !
Trying to squeeze the brakes rather than jamming on. IDK. Sent from my iPad using Tapatalk |
![]() Drives: 2013 BMW M3 Join Date: Jul 2016
Are you using your left foot for braking? I am on the stock pads and I haven't encountered this "ice mode" in a straight line stop.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Never heard of ice mode.
If I'm hitting ABS, driver needs to be smoother until I get some heat in the tires. |
Unfortunately not left foot braking and I'm sure the vehicle going into ice mode probably shows some bad driving habit that I have but it just seems to not be very consistent.
#6 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
It might not be 'ice mode' per se . . . perhaps you're seeing 'brake assist' activity instead?
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
#7 |
I changed to yellow Koni shocks this year and found my driver's front strut had no rebound and weak compression compared to the passenger front. It has made the car handle much better through quick transitions and long slaloms. Perhaps the hard brake pedal (ABS or Brake Assist) is caused by inconsistent wheel contact with the ground, a bumpy course combined with weak struts. Just a thought.
#8 |
I made the Koni swap also and the stock struts don't feel right at all 18k miles.
And I do feel your on to something with the tire lift Cars thinking it's on Ice and all you get is .8 g. Of stopping force. Drawback of Koni's my 275/40/20 will not clear the spring perch. Sent from my iPhone using Tapatalk
#9 |
Instagram: Sangstah
Does this ICE mode get triggered with all the nannies off or on?
#10 |
#11 | |
A little dirty, drove through several storms in Texas and Oklahoma before and after the College Station Champ Tour. Last edited by RKeeton; 12-14-2017 at 04:46 PM. |
#12 | |
I ended up putting same size(285/35-20) MPSS on the front and a pair of GYs on the rear that I had in the basement. Even the pilot sports are "close " ![]() If my skills with the Quick Trick alignment kit it's 1.7-1.8 camber my autocross tires fit with plenty of room. ![]() 305/30-19 Sent from my iPad using Tapatalk |
#13 |
I've had many encounters with ice mode. I ran Hawk HP+ front pads and stock rear pads for a while, worst idea ever.
Also I've found that he driver is typically the reason you get ice mode. Stabbing the brake pedal right after hard acceleration is what's causing it, its exaggerated when you have different pad compounds front/rear. Brake a little sooner and smoother and you'll never have an issue with it. |
#14 | |
Yep , this is what I figured it's not the car it's me. Little too excited with the last second brake spikes! Try to squeeze out the last couple of tenth's Sent from my iPhone using Tapatalk |
