Old 04-08-2017, 09:52 PM   #1
BandRcAMARO
Drives: 2010 Camaro 2SS/RS
Power seems low with mods??
I had my car dyno tuned by Dr Phil, only made 453 to the wheels and 417 torque. Its a 2010 ss with the ls3, k&n cai, tsp 1 7/8s headers, borla muffler, and tsp stage 3 cam, specs are 231/236 and 111 lsa. From lurking on here it seems low, car seems like it has a ton more power but the numbers kinda confuse me.
BandRcAMARO is offline   Reply With Quote
Old 04-08-2017, 10:34 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
What are you expecting it to be?
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 04-08-2017, 11:10 PM   #3
BandRcAMARO
Juat goin off the dynos here with similar mods, ppl are usually making over 460 no problem
Old 04-09-2017, 09:19 AM   #4
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
The M6 will show a little more then then the auto's
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 04-09-2017, 02:29 PM   #5
ecreps
Drives: 2014 1LE, 1996 z28
Dyno calibrations are all over the place. My advice would be to see what it traps at 1/4 mile; and compare that to others with similar mods.
ecreps is offline   Reply With Quote
Old 04-10-2017, 08:07 AM   #6
BandRcAMARO
Yea just waiting for a chance to run it in the 1/4. I should see 2 or 3 mph added onto it, best ever before was a 113.7 mph
Old 04-15-2017, 10:08 AM   #7
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Not only is there variance between dyno to dyno of the same brand there's a huge difference between brands of dynos. Example Dynomax usually gives a better number than a Mustang.
Don't get hung up on numbers... is the car faster? Yes? Good.
Do you think it's fast enough? I'm going to gyess by the end of next week you'll want more... lol
Sent from my SM-G935V using Tapatalk
Firefighter is offline   Reply With Quote
Old 04-15-2017, 01:56 PM   #8
07-SRT
07-SRT's Avatar
Drives: 2022 Camaro SS 1LE
Dr. Phil as in Tampa Tuning?
2022 Camaro SS 1LE
07-SRT is offline   Reply With Quote
Old 04-15-2017, 02:18 PM   #9
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
I'm not super familiar with the LS3 motor, but I know that with the L99 and GPI's SMALLEST cam most are seeing about 450 RWHP....
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
