Old 04-09-2017, 07:36 PM   #1
Iowa1LE
Iowa1LE's Avatar
Drives: 2014 Chevrolet Camaro 2SS 1LE
Rotating tires on rims?
Is it alright to rotate the stretched rear tires onto the slimmer front rims? I'm assuming it won't be a problem.
Iowa1LE is offline   Reply With Quote
Old 04-09-2017, 10:11 PM   #2
SSMY1LE
SSMY1LE's Avatar
Drives: '14 1LE RS NPP Recaro
If you have enough rubber left on the rears to put on the front then...........you're driving it wrong !!
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be
SSMY1LE is offline   Reply With Quote
Old 04-10-2017, 12:02 AM   #3
Iowa1LE
Iowa1LE's Avatar
Just figuring you could make a set last a little longer.
Old 04-10-2017, 11:34 AM   #4
PapaKlutch
PapaKlutch's Avatar
Drives: 2015 Camaro SS/1LE
Yes, it's A-OK. Lots of 1LE owners have done just that.
2015 2SS/1LE/RECARO/NPP/RS/NAV
PapaKlutch is offline   Reply With Quote
Old 04-10-2017, 12:09 PM   #5
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
When the first set of rears went away, I put a brand new tire on all four corners and saved the two front tires. When the rears in that second set were toast, I had the saved fronts mounted on the rear and got about 7k more miles out of that set up. I will do the same this go around, but I am at about 50,300 miles and have decent tread left and am on the third set of tires.
To answer your question OP, go for it!
gajagfan is offline   Reply With Quote
Old 04-11-2017, 01:53 AM   #6
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
Nah.
Don't do it to a sports car, that depends on driving feel, handling, grip. It never feels the same again, it just doesn't.
Camaro Dude is offline   Reply With Quote
