#1 | |
![]() Drives: 2013 Camaro ZL1 Join Date: Sep 2013
Weird Idle Above 30 mph
Alright you guys were spot on with my last problem! I hope you can help me out again!
When my car is cold and even when it warms up, it randomly spikes in revs from 500 rpm's to 1,000 rpm's when I am going 30 mph or more in neutral. Here is a video of it: Please ignore my loud annoying radar detector, and the poor quality of video. Sometimes its almost like the car will stall out an drop to 300-400 rpm's. Could it be a bad idle control motor?? What do you guys think?
2013 Yellow Camaro ZL1
Purchased: (9/24/16) 5% Tint All Around 45% Tint on Windshield Roto-Fab Cold Air Intake Oracle Afterburner Tail Lights Oracle LED Sidemarkers RDP Tune TSP Long Tube Headers Forza Componenti 3-Way Exhaust Controller ZL1 Addons Wicker Bill |
"BEASTM*DE"
How long are your holding it in neutral and why???Could be active rev matching trying to determine if you're attempting to down shift...Just guessing...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
#3 | |
I don't think the 5th gens offered active rev matching in the manuals.
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
Sounds like there's a vacuum leak somewhere. You might start by checking the connections on the Roto-Fab intake, especially after the MAF sensor.
![]() Drives: 2013 ZL1 Join Date: Sep 2015
I have a similar type of issue. I didnt really notice it before I installed my headers and had the car tuned. So Im not sure if it is a tune issue or what.
#6 |
![]() ![]() ![]() ![]() ![]() Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Definite vacuum leak... Check as suggested above and also the CAI tube connection to TB and filter element to make sure they are still air tight sealed.
#7 |
If it were a vacuum leak, why wouldn't it do it all the time? Why just while the car is rolling? My car does something similar to this while coming to a stop and the car is in neutral. I also have rotofab intake, headers (no cats), and a tune.
#8 | ||
2013 ZL1 CRT M6
__________________________________________________ ____________________________________ Current Mods: Rotofab CAI, Big Gulp, and Res. ATI Superdamper and 10" Lower, DSX FF Sensor, DSX Aux Fuel Pump, ID850s, Kooks 1 7/8" Headers, Forced Induction Interchiller, McLeod RTX Twin disk. DSX Tuned. Running on 20" MT ET Street SS on stock wheels for the strip. Best 1/4 mile to date:10.81 @130.43 mph w/ 1.61 60' Just added: Jokerz Stage II blower port and FI Interchillers blower lid spacer. |
#9 |
I will check this when I get home today from work.
#10 |
Do you think I have a leak somewhere in the exhaust?
#11 |
That is very odd yours does the same thing.
#12 |
ZL1 Pilot
Look at your vacuum/boost gauge. Is it normal? I doubt it's a vacuum leak. Since you're tuned, I bet spark smoothing has been disabled in your tune. (some tuners do this) I bet this is being caused by a wild swing in the timing tables. More of an issue with big cams. Mine does it every once in a while.
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs |
#13 |
![]() Drives: 2013 ZL1 M6 Join Date: Sep 2016
My car does the same thing. It started after I had the parts in my signature installed. I have never got around to asking the tuner about it.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP 630.35 RWTQ |
#14 | |
