04-12-2017, 06:21 AM | #1 |
ruff ruff
Drives: 2010 2SS/RS Join Date: Dec 2006
Radio temperature display wire color.
I had the Metra kit, changed to the PAC kit, I just left all the metra wiring in place and only used the PAC wire harness. Everything works great except my temperature display on the PAC shows only ---F. I don't see on any wire diagrams anything about a wire for temp display, so trying to figure out if a wire came disconnected, but I have no idea what color wire is the right one. The temp display worked fine on the Metra one.
2010 2SS/RS, XO Verona wheels, BC coilovers oem ZL1 bumper conversion Kenwood ddx9905s, maestro, Kenwood xr1s, xr4s, kappa 1200w,subs, Kenwood xr comps and rear deck speakers, long tubes, hf cats, speed secrets tune, custom exhaust, CAI, blacked out everything.
04-12-2017, 11:14 AM | #2 |
H-Town Camaro Club
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP Join Date: May 2014
If the PAC support thread doesn't have an answer (or installation instructions), you'll need to mail PAC.
04-13-2017, 05:29 AM | #3 |
ruff ruff
I called PAC, tech guy was a worker from a totally different department filling in, asked his coworkers and they said they never ran into this issue, kit is so new, try unplugging temp display wires and check for bent ones. So didn't help at all.
04-13-2017, 07:02 AM | #4 | |
H-Town Camaro Club
Ok. Call back next week, email them, call your dealer who sold you the kit, RMA a new one and/or ask the PAC support thread (whom isn't having trouble with the temp display).
04-14-2017, 03:01 PM | #5 |
ruff ruff
Others I did email with no Temp working on the thread and they fixed it because plug was loose. Mine is not, so going to call PAC again.
04-14-2017, 03:04 PM | #6 |
ruff ruff
Even with this issue, I like it much more than the Metra kit, temp display I could care less about it it actually said ss or Camaro, but once startup screen goes to temp - - - F looks stupid lol worst case I could find a small SS or Camaro emblem and cover up the display, but want it working since I paid for it.
04-16-2017, 10:46 PM | #7 |
ruff ruff
I called PAC again, the designer was out of country, so need to wait until he returns. Today I noticed, the Metra harness has 8 pins on the main harness and PAC only has 7. So wondering if mines missing 1 pin and wire. Also I reconnected the Metra face and harness and my temp display worked right away, so only thing I can think could be causing the PAC kit to not display temp is the 1 less pin.
04-19-2017, 04:26 AM | #8 |
ruff ruff
Can anyone verify the pins # on the white harness that plugs into the factory harness then to the HVAC(black end). My Metra kit had 8 pins on the harness, this PAC one has 7, trying to figure out why I have no Temp display on the PAC kit, but works on the Metra.
04-19-2017, 04:51 PM | #9 |
Drives: 2011 Camaro LS Join Date: Apr 2017
Sounds like you're missing the single wire CAN connection, the Metra kit kinda does the same thing without that connected.
Pin 1 - HS CAN High Pin 2 - HS CAN Low Pin 3 - NC Pin 4 - ? Pin 5 - GND Pin 6 - GND Pin 7 - GND Pin 8 - LIN Pin 9 - SW CAN Pin 10 - VCC Pin 11 - GND Pin 12 - GND Pin 13 - ? Pin 14 - GND Pin 15 - ? Pin 16 - ? Pin 17 - GND Pin 18 - GND No idea what the '?' connections are, most likely actuators, or maybe limit switch inputs. |
04-19-2017, 05:01 PM | #10 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
Pac 5 is still its the best looking kit out there, Metra and Scosche just did not do it for me.
Hot Wheels Emblems and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills, Hot Wheels door Sills.
04-19-2017, 06:54 PM | #11 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
04-19-2017, 10:13 PM | #12 | |
ruff ruff
04-26-2017, 04:18 AM | #13 |
ruff ruff
This is really irritating me, called PAC 3 times, been emailing tech. So far all they say is everyone thinks it's a installation issue. Only difference between connecting metra kit(,temp display working) and PAC is connecting the HVAC harness. Wish I could get the PAC kit to just show SS or Camaro all the time, I just don't like seeing - - - °F
04-28-2017, 02:04 PM | #14 |
ruff ruff
If anyone has a PAC hvac harness easy to look at could you compare pins to mine to see if same. Thanks
