Old 04-12-2017, 03:46 PM   #1
bpal11
bpal11's Avatar
Drives: Victory Red 2011 Camaro 1LT
Oil leak on header near the gasket??
Hey guys, I recently had BBK LT headers installed and now im getting an oil leak from the front and middle headers on the driver side. When I wake up in the morning, the leak is there (a mild leak). It will leak a little more from a cold start, but when it is hot there's no leak.
Does anyone know what could be causing the problem? The car had no problems before the header install, and the headers are tight and don't seem to be cracked.
2011 Camaro 1LT - Victory Red
Af dynamic CAI, Vmax ported TB and Iceolator, BBK LT headers, Pypes Catback, Vitesse Throttle Control
Tints all around, 6th gen style fender emblems
bpal11 is offline   Reply With Quote
Old 04-12-2017, 05:02 PM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Did you use the OEM gaskets or bbk's? The OEM ones are very good and I chose them over the BBK's.
Edit: should've reread the OP, post up a pic to confirm the oil leak. I know when I installed my HFC's they became loose and had a exhaust leak. Black droplets leaked out.
Lil' Nasty is offline   Reply With Quote
Old 04-12-2017, 05:18 PM   #3
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Is it on the top side of the header and running down on the header or leaking under the header and running down the block? Header gaskets have nothing to do with an oil leak, nor does a damaged or cracked header, now an exhaust leak yes.
HOJO is offline   Reply With Quote
Old 04-13-2017, 09:06 AM   #4
bpal11
bpal11's Avatar
I used the BBK gaskets and they definitely do not seem very good, I will post a picture soon.
Old 04-13-2017, 09:08 AM   #5
bpal11
bpal11's Avatar
It's on the top side of the header and it runs down the header... exhaust leak?
Old 04-13-2017, 09:29 AM   #6
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Do that for sure, because if you didnt see a leak before the install it might be a exhaust leak.
Old 04-13-2017, 03:41 PM   #7
tlavoie87
Built Not Bought
tlavoie87's Avatar
Drives: 2010 Twin Turbo LFX
another note when installing headers..do not OVER Tighten ..torque them to specs you can distort the flange if you over tighten.. I used new factory metal gaskets never leaked
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014
"Built Not Bought!'
Sponsors:
OverKill Motorsports
tlavoie87 is offline   Reply With Quote
Old 04-17-2017, 10:48 AM   #8
bpal11
bpal11's Avatar
Here's the best picture I could get, the brownish is the oil. It looks to be seeping out of the header where the gasket is
bbk, cold start, headers, oil leak
