Old 04-15-2017, 02:49 PM   #1
SarGar
Drives: '13 BRM ZL1
Best pulley set up for cam'd Z
So, I'll be camming the Z for sure by the end of summer. What pulley setup are you guys seeing the best with a cam? Upper only 2.3/2.5 or maybe the 2.5 - 9.1 combo...just seeing what you guys are having the best results with.
Thanks!
SarGar is offline   Reply With Quote
Old 04-21-2017, 12:33 AM   #2
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
I'm not cammed, but I've read many post with the 2.5/8.6 or 9.1 running safely...Your best info will come from whomever is doing the install...Good luck...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 04-21-2017, 10:30 AM   #3
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Yeah I'd recommend a 2.5 + 8.6 if you're going to run 93. If you're going to do E85, then you can do a 9.1" instead of 8.6 which would give you another 10-20 ponies.
What is the rest of your build? Injectors? Heat exchanger? Meth? E85? Intake? Exhaust? 102mm? Porting?
Can'tHave2MuchHP is offline   Reply With Quote
Old 04-21-2017, 11:47 AM   #4
leemozoid
leemozoid's Avatar
Drives: '15 Silverado LTZ & '13 ZL1 ragtop
I have a 9.17 lower and plan on staying with just pump gas (E10/91 and 100% 93). The upper pulley is stock. Currently I have 850s which flow 104 lbs @ 58 psi. I will have a BTR Stage 3 cam installed soon. I was thinking about 2.75/2.85 to keep boost at or under 13 psi. Good decision?
leemozoid is offline   Reply With Quote
Old 04-21-2017, 12:01 PM   #5
TTTAPOUT
Drives: 2013 ZL1
I am running the 2.55 and 9.17 with great results. I am also planning to add the BTR stage 3 cam sometime this summer, and the flex fuel kit. With CAI, LT, 1050X injectors and the pulleys, I made 615/625 to the wheels on a very low reading dyno.
TTTAPOUT is offline   Reply With Quote
Old 04-29-2017, 09:56 PM   #6
Smittty
Smittty's Avatar
Drives: 2013 ZL1 Camaro 2000 SLP Camaro
I went with a 2.5/10. combo with good results.
2013 ZL1 748rwhp & 733 rwtq ( 93 tune )
Smittty is offline   Reply With Quote
Old 05-01-2017, 11:20 AM   #7
GONMAD510
Drives: 2013 ZL1 M6
I am running the 2.55 with and 8.6.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 05-01-2017, 07:54 PM   #8
polarisiq93
polarisiq93's Avatar
Drives: 2013 ZL1 M6
I have the 2.5 9.1 on mine with btr 3, started with the 8.6 but changed out for a 9.1. its the best combo imo
polarisiq93 is offline   Reply With Quote
Old 05-02-2017, 01:02 PM   #9
Can'tHave2MuchHP
Drives: Fast
2.5 + 9.1 is fine, though I'd prefer a 8.6 if you're running on 91 or 93. If you're on E85 (even a 50/50 mix) then go for the 9.1. I think you'll have to pull just a little too much timing on 93/91 to make the 9.1 worth it.
Old 05-02-2017, 09:45 PM   #10
DaveZL1
Drives: '15 ZL1
why not stock upper/10.5 lower?
DaveZL1 is offline   Reply With Quote
Old 05-03-2017, 05:32 PM   #11
jrhagen
Banned
Drives: Camaro
2.55/9.5.
jrhagen is offline   Reply With Quote
Old 05-03-2017, 05:39 PM   #12
Can'tHave2MuchHP
Drives: Fast
Originally Posted by jrhagen View Post
2.55/9.5.
A lot of supercharger RPM for longevity and lot of heat if you don't have a serious amount of cooling mods (You'll need E85, Meth, Upgrade HX, Expansion tank, or an Interchiller to cool that).
Old 05-03-2017, 05:51 PM   #13
jrhagen
Banned
Drives: Camaro
Got them all except corn.
Old 05-03-2017, 06:08 PM   #14
Can'tHave2MuchHP
Drives: Fast
How much HP do you make? With that much boost the pulled timing would be pretty bad without E85 even with your other mods.
I see you have an LSX block so you may have a completely different animal than what we're running.
