04-16-2017, 12:38 PM | #1 |
Drives: 2013 ZL-1 Join Date: Apr 2017
2013 Zl1 under 3500lbs
I just purchased a silver 2013 manual zl1, I'm looking to go below 3500lbs, but keep stereo, ac, and still be streetable.
Just FYI car has a salvage title, so I'm not ruining a virgin collector car, it is a car that others walk away from anyway ,so I figure why not make it a light ,hot street car that is really fun to drive. I'm thinking about cutting the frame rails fwd of strut towers ,race seats, no sound deadening, light battery and wheels, lots of aftermarket aluminum suspension parts. Also I'm sure under the interior panels there is a lot of structure metal that can be removed.....any I missing anything ? |
04-16-2017, 12:53 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
If you wanna ditch wheels I might be interested.
Orange Krush II
04-16-2017, 02:23 PM | #3 |
KaBoom1701
Mods:
04-16-2017, 02:39 PM | #4 |
Drives: 2014 SIM 2SS Join Date: Sep 2015
Have you weighed it yet to see how much weight you'll need to cut to meet your target?
04-16-2017, 02:41 PM | #5 |
To weigh it now wouldn't tell me much. It was a recovered theft car with no engine or trans..
04-16-2017, 07:59 PM | #6 |
KaBoom1701
I would bet the max weight you can take from a ZL1 without getting to crazy is around 200lbs....
Mods:
04-16-2017, 08:43 PM | #7 |
Drives: 2013 ZL1 Join Date: Jan 2015
This is copy and pasted from a post 6 years ago.
You can easily lose 250lbs and keep the car complete with light wheels, seats, battery, remove back seat, etc. 600 lbs will take a bit more aggressive and creative weight loss. A complete ZL1 starts around 4100. -6 Airbags (Side Curtain, Seats, dash) (-13.4 pounds) Dash removed, lightened, tubular steel loop cut off of cross brace, cross brace lightened, sound deadening removed from backside of FW (-30 lbs) Removed rear seats, belts and brackets, and sheet metal holding bracket mounts (-45.4 pounds) Weld RT-S & tires vs stock 20s (-85 pounds) Headers/X/Dumps at axle for weight (-60 pounds) Tubular front crash support (-12 pounds) Remove rear crash support (-26 pounds) !Evap (9.7 pounds, not including evap line, which I left in) !A/C (-49 pounds) !Wiper Motor Assy (-9 pounds) !Junk Block Oil Cooler/Heater, unnecessary (-7 pounds) Lightweight Billet clutch vs. stock (-12 pounds) Sound deadening removed from under seats, backseats, trunk, including hood/trunk liner (-8 pounds) Braille battery (-29 pounds) Windshield Washer Tank + Pump and lines empty weight (4 pounds) ITEM WEIGHT (LBS.) LOWER REAR SEAT 10.2 UPPER REAR SEAT 28 DRIVERS SEAT 54.6 PASSENGER SEAT 44 A/C EVAPORATOR CORE ASSY. 13.4 A/C COMPRESSOR 13.2 A/C CONDENSER 6.4 A/C-HEAT BLOWER MOTOR ASSY 4.2 A/C LINES AND DUCTING 7.6 A/C FIREWALL COVER 3.6 DRIVERS AIR BAG 1.6 PASSENGER AIR BAG 5.4 SIDE AIR BAG (EACH) 3.2 FIREWALL INSULATION 2.8 FLOOR INSULATION 12 TRUNK CARPET AND WELL COVER 15.2 TRUNK COMPRESSOR 6 TRUNK-LID STRUTS (PAIR) 1 FRONT BUMPER 14.6 REAR BUMPER 26.4 RADIO 4 DOOR SPEAKERS (PAIR) 3.6 FLOOR MATS (FRONT PAIR) 4.8 CENTER CONSOLE 8.2 EMERGENCY BRAKE LEVER W/CABLES 6.2 FRONT SEAT BELTS (PAIR) 6 REAR SEAT BELTS (PAIR) 3.6 FRONT BRAKE ROTORS (EACH) 25.4 REAR BRAKE ROTORS (EACH) 24 FRONT CALIPERS (EACH) 11.4 REAR CALIPERS (EACH) 7.4 HOOD 25.3 HOOD INSULATION 1.2 HORNS (PAIR) 1.4 WIPER ASSEMBLY W/MOTOR 8.6 WINDSHIELD COWL PLASTIC 3.6 DRIVESHAFT – 6 SPEED MANUAL 24 FUEL TANK SHIELD 2.8 DRIVE SHAFT HEAT SHIELD .8 STOCK AIR BOX 7 ENGINE COVER 4.4 CLUTCH ASSEMBLY (INCLUDING FLYWHEEL) 57
2013 A6 ZL1
04-16-2017, 09:08 PM | #8 |
Im thinking alot of sheet metal can be removed in the structure of the car in a strategic ways to lessen the weight further , and keep some luxuries.
does anyone make aftermarket front and rear tubular subframes ? there looks like 200lbs to lose there, they are way heavier than they could be. |
04-16-2017, 09:42 PM | #9 |
Drives: Fast Join Date: Mar 2015
No way you're getting 3500 IMO. Car is 4100+ (Even coupe manuals). If you took the entire interior out, light weight battery, and bought light weight wheels, you'd probably drop 300 pounds maybe...
The weight is in the width, height, and thickness of the car. The magnetic suspension system, the heavy duty drivetrain, and built trans. This is unsheddable weight and it's where most of it lies. Nick (GuitarmageddonZL1), took his entire interior out, and it totally wasn't worth it IMO, he dropped like 130 pounds I want to say and immediately put a good part of it back with a cage to run the times legally. Not worth it...IMO race it full weight and accept what it is. |
04-16-2017, 09:58 PM | #10 |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
If you manage to drop 1000+ pounds the car will twist into a pretzel as soon as you hit the throttle. A huge amount of the weight is the drivetrain itself. Maybe 600 pounds at best with everything swiss cheese'd. Better to just make more power.
04-16-2017, 10:28 PM | #11 |
Im looking to drop around 600lbs, not 1000. 4100-600=3500
not willing to remove ac, radio or door bars. totally willing to remove alot of other stuff |
04-16-2017, 10:28 PM | #12 |
Drives: 2010 SS L99 IOM Join Date: Aug 2012
I think you can do it. It'll get expensive if you start doing light materials.
Do your research and you'll achieve whatever goal you want to hit.
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins |
04-16-2017, 10:35 PM | #13 |
As a general rule on cars like the ZL1, losing 500 lbs is about equivalent to gaining 100whp. Clearly it's much easier to gain 100whp than lose 500lbs. With that said losing the independent rear suspesion, light weight seats, wheels, rotors, light battery, you will lose 300+.
Much past that and you will need to gut the AC, the interior, and cut structure. There was a company that made a tubular front "k member" but don't know if they still do.
2013 A6 ZL1
04-16-2017, 11:26 PM | #14 | |
Still is easier to just add power. A hundred wheel is super easy. After 200 plus it begins to be a little more challenging. |
