Old 04-17-2017, 09:05 PM   #1
15xracing
15xracing's Avatar
Drives: 2011 Camaro ss 6.2L L99
New here! Ss2 vvt cam, stall?
Hey first time posting in the forum here. I have a 2011 ss l99 and have done all the installs myself for, vmax tb, cai intake, gpi ss2 vvt cam w/afm/dod delete, muffler Delete, Stainless works LT, and dyno tune. I ran a 12.8 in 1/4 and I'm at 431 hp to the wheels..
Now my question here is, what stall converter should I get for this cam I have? Gpi recommended at least 3600 but I want to know best brands, single or multi disc and best stall amount I should have for the best performance.
Keep in mind I do plan on going to 3.91 gears too..
Thanks!
15xracing is offline   Reply With Quote
Old 05-12-2017, 07:13 AM   #2
camrytt
camrytt's Avatar
Drives: 2017 ZL1 A10
I was looking at getting an ss2 and looking up converter recommendations as well. You get any info?
Current: 2017 ZL1 A10
previous: 2019 1SS A10
previous: '14 L99, CAI intake, vmax ported tb, e85 kit, stage 2 cnc heads, speed engineering long tubes, custom high flows, resonated x pipe, muffler delete, qtp cut outs, gpi ss3 vvt Cam, zl1 pump and injectors, fti triple disc, mayhem motorsports trans cooler and tune, ngk spark plugs +red msd wires, 3.91 gears.
Past: '12 LFX, full bolt ons + E85, 302hp/267tq
camrytt is offline   Reply With Quote
Old 05-12-2017, 07:24 AM   #3
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
I have the GPI SS2VVT cam and a Circle D single disc 3C (3600) converter. Had planned on going with the multi disc, but after speaking with Ryan and also with Circle D I went with their recommendation for the single disc. I also have 3.91's.
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 05-12-2017, 08:03 AM   #4
URDAMAN
URDAMAN's Avatar
Drives: 2010 IBM 2SS / RS
Great choice in cam setup, I would def go with the circle d 3600 for that cam, triples have more weight to spin being heavier. Less mpg as a daily un less a strict dragger. Because they use loose fluid coupling to light their large chargers and rely on lock up to put their power to the ground, not fluid coupling. But if its not your daily, def a triple. Just my opinion...either way awesome. You ll also definitely benefit from the gear swap
URDAMAN is offline   Reply With Quote
Old 05-12-2017, 08:19 AM   #5
URDAMAN
URDAMAN's Avatar
I have the GPI SS4 setup and other goodies with a 5c multi converter it flashes about 4200. Absolutely love the setup, from basic bolt ons ran 12.3's on a good day to 10.5's to 10.8's
Old 05-12-2017, 11:10 PM   #6
15xracing
15xracing's Avatar
Hey guys I ended up talking to someone at circle d. they got all the camb specs for the converter and with the help of gpi decided on the single disc 3800 circle. It just came in about three days ago and I'm currently installing it
Old 05-12-2017, 11:14 PM   #7
15xracing
15xracing's Avatar
Get the 3800 single disc circle d.. The ss2 cam is great! But if you can I would go ss3.. only reason I went ss2 was because I wasn't getting a stall right away. Wish I went ss3 now... lol
Old 05-12-2017, 11:52 PM   #8
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
Why's that?
Does SS2 lope/chop at all?
Dmpsix is offline   Reply With Quote
Old 05-13-2017, 02:28 AM   #9
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
I know all dynos read differently, but 431 seems low for a SS2....
I've seen quite a few dynos from SS1 cammed L99's making like 450 RWHP...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 05-13-2017, 09:00 AM   #10
camrytt
camrytt's Avatar
Funny enough, I emailed Gpi and they recommended I just get the ss3 too, with a 4c torque converter.
Old 05-13-2017, 10:17 AM   #11
URDAMAN
URDAMAN's Avatar
Either way you cant go wrong. If you plan on fi in the future perfect cams plenty of power through the bands. Dont let dyno numbers fool you, track it and youll see. I definately recommend gears for sure
Old 05-13-2017, 10:41 AM   #12
URDAMAN
URDAMAN's Avatar
To be honest SS2 is an entry level (mild) cam compliments your bolt ons as it is. You can go fi later and beast it. Most of our cars with standard bolt ons tune about 370 to 380 so if your stuck on numbers 50 hp gain not to shaby from adding a cam alone. Also, other supporting mods will increase your hp, ported throttlebody, radius rod mod on intake manifold, udp, and getting rid of your cats
Old 05-13-2017, 12:54 PM   #13
15xracing
15xracing's Avatar
Originally Posted by Dmpsix View Post
Why's that?
Yeah ss2 lopes and is choppy and sounds amazing.. It's mainly because you can get a lot more power with the ss3
Old 05-13-2017, 01:00 PM   #14
15xracing
15xracing's Avatar
Yeah I don't understand it either.. I'll keep on messing around with it and see if I can bump those number up
ss2 vvt cam, stall converter
