Old 04-20-2017, 10:54 PM   #1
SAVE FERRIS
Drives: 2015 1SS L99 Convertible
So, I want to purchase an OEM Supercharger w/o wiring...
Anyone know what wiring is needed for that application? I've found a used one locally with 27,000 miles on it and it's got a nice price.
Kit includes:
LSA 1.9L supercharger (low mileage take off unit) all bolts & hardware included
ZL1 supercharger lid for LSA 1.9L supercharger (OEM)
ZL1 fuel rails and feed line (OEM)
LSA fuel injectors & fuel rails (OEM)
Evap sensor and purge tube (OEM)
Tensioner, mounting bracket, and hardware (OEM)
LSA accessory drive idler bracket with pulleys and hardware (OEM)
OEM accessory drive belt
ROTTO FAB Cold Air Intake and filter
ZL1 heat exchanger and mounting brackets (OEM)
oem Intercooler reservoir, mounting bracket, and hoses
intercooler pump (OEM)
TB, MAP, and IAT (OEM)
So, this looks like everything minus a tune and wiring. So, what's the wiring needed and... will a salvage ZL1 ECU work on my SS or tune It? Obviously the ECU would be cheaper?
Thanks,
SAVE FERRIS is offline   Reply With Quote
Old 04-21-2017, 10:43 PM   #2
Dentpounder
Drives: 2013 SS/RS L99 Convertible E forced
You need to post this question in the Forced Induction forum. Tons of quality help there!
Dentpounder is offline   Reply With Quote
Old 04-22-2017, 12:13 AM   #3
hammdo
'It's an experiment'
hammdo's Avatar
ECM from a zl1 will not work. ADM has a kit and the wire extensions for the MAF, Evap, and throttle body. Also, you can buy the pulley system in order to keep your stock accessories.
My build thread show a basic DIY starting here:
http://www.camaro5.com/forums/showth...=385577&page=5
ADM stage1 kit:
https://lsa-conversion-store.myshopi...onversion-kits
Parts:
https://lsa-conversion-store.myshopify.com/
https://lsa-conversion-store.myshopi...sion-kit-parts
-Don
747 RWHP 794 RWTQ
