Old 04-24-2017, 01:31 AM   #1
wsmith
wsmith's Avatar
Drives: 2011 LS
Brake Upgrade for 2011 LS v6
I was wondering if someone has any suggestions for a brake upgrade over a stock 2011 LS v6 system. I want some cool looking GREEN painted (why does it seem like nobody makes a synergy-type green caliper?) superior brakes for my car but the only things I can find cost $2,000-3,000 just for front or rear. Is there anything that's better than stock that doesn't cost me $5,000-6,000 for all four wheels?
Also, if I upgrade, do I need new brake lines, fluid, master cylinder? And if so, how easy is all of this to install myself?
MRT V 1.0, Injen intake, ICE-olator, JVC Stereo, Alpine speakers, 600-w Amp, 10" Subs
wsmith is offline   Reply With Quote
Old 04-24-2017, 07:33 PM   #2
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
Not sure if you are dead set on GREEN but for the record... I picked up a set of Brembo's powder coated red calipers from a 2014 SS 1LE for $400 shipped to my door. Came with used rotors, pads, lines (~30k). Expecting to get through the summer with them and then reevaluate. I'm having them installed tomorrow (believe it or not) by the dealer in Lynchburg, Virginia (Pinkerton). I also bought a master cylinder for $60 from a SS and get $15 back (core charge) at a local salvage yard.
These are a direct bolt on replacement to the V6 and require no modification. I believe the rears do require minor modification of the dust shield but I'm only doing fronts at this point. We will see how much the dealer will end up charging me for install but I believe the quoted around $300. I know this is not a super challenging process to swap the brakes and many members have done it themselves but I currently live in a loft and don't feel like tackling this project in the parking garage.
I would give up the GREEN DREAM and find a set of used Brembo's in the classified section on here if you're not trying to spend big money. You can always have them powder coated afterwards if that's what you wanted to do.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 04-24-2017, 10:58 PM   #3
seanjhon
seanjhon's Avatar
Drives: 2013 camaro
Yes I agree with the poster above. Get you some brembos from a seller here, then if you want them your color, ship them off to the powder coater guy on the forum. You can check if he is still on here. He can paint them what you want. You send him yours and he sends you a pair, rebuilt and powder coated your color.
Or you can get a paint system like G2 and they can send you your paint color I believe and you can paint them yourself.
You have options if you have any questions feel free to PM me. I actually upgraded to the brembo system and used the G2 paint and painted mine red. I also got some high heat decals (CHEVROLET and BREMBO) and put them on.
Good luck
seanjhon is offline   Reply With Quote
Old 04-25-2017, 05:30 PM   #4
sspade
sspade's Avatar
For the record... just picked my car up from dealer. 330$ total including fluid.
HUGE difference in braking and pedal feel. Even with half worn used breaks. Super happy with this upgrade!
Old 04-25-2017, 05:48 PM   #5
Silent...
Silent...'s Avatar
Drives: 2012 2LT RS White Born: 11/10/11
I just did an upgrade on the fronts - Cadillac ATS Brembo fronts and rotors, plus rear rotors. Hard to be the price for new parts. It's all shown here. http://www.camaro5.com/forums/showthread.php?t=492499
*Grey Hockey Stripes; Heritage Grill; GM GFX - Unpainted Argent Gray; GM Dovetail Spoiler; Rivercity Creations custom painted rear bowtie, RS & Taillight Bezels; MRR M017 Graphite Wheels; Nitto NT555 G2; ACS 4Teen Heat Extractor
*RX Catch Can;CAI; MF Exhaust; VMAX CNC Spiral Ported TB; Overkill Stage 1 Supercharger System; Hotchkis Comp Sway Bar Set w/ End Links, Cadillac CTSV 4 Piston Brembos on all corners with SS Black Hat Rotors
Youtube Channel - HPDE Driving Videos https://www.youtube.com/channel/UCpO...8aw6hgX3O1Uh7A
Silent... is offline   Reply With Quote
Old 04-25-2017, 11:17 PM   #6
Santos
Santos
Santos's Avatar
Drives: 1SS Blk 6M ECS 1500
I have a set of 4 Brembo ss calipers boxed up ready to ship they will need new pads but they are great condition
Santos is offline   Reply With Quote
Old 04-26-2017, 02:02 AM   #7
wsmith
wsmith's Avatar
Drives: 2011 LS
Will SS rotors fit on the axle? Assuming I have 20" wheels of course.
Also, do I need new brake lines and a new master cylinder or can I reuse them?
Old 04-26-2017, 07:32 AM   #8
sspade
sspade's Avatar
Did you read what I wrote above?!
DIRECT BOLT ON REPLACEMENT.
Rears will require the dust shield to be trimmed. Thats it. Fronts require no modification whatsoever. Master cylinder is not required but recommended. Pick one up from salvage yard for fifty bucks. You will need SS lines but they should be included with calipers.
Old 04-26-2017, 11:53 AM   #9
Santos
Santos
Santos's Avatar
http://www.camaro5.com/forums/showthread.php?t=490960 , for 700 I can have them powdercoated synergy green or any color thats a few hundred less than some others offer PM me if interested
Old 04-26-2017, 06:54 PM   #10
wsmith
wsmith's Avatar
Drives: 2011 LS
PM sent.
Old 04-26-2017, 06:55 PM   #11
wsmith
wsmith's Avatar
Drives: 2011 LS
Oops, sorry about that. I really appreciate the advice; thank you!
Old 04-26-2017, 09:40 PM   #12
Avenging Orange
Avenging Orange's Avatar
Or......you can simply paint them the color you want. I did mine with a rattle can 3yrs ago....still looks new. Get you some new Brembo decals on Ebay.
But yes, the Brembo upgrade is probably the cheapest/easiest route.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 04-26-2017, 10:26 PM   #13
ScottinKC
Drives: 2010 Camaro 2SS
Brembo
I just swapped out my Brembo's for a different set painted red. If you want the Brembo calipers I took off I would sell them for $400 shipped.
ScottinKC is offline   Reply With Quote
Old 07-05-2017, 06:36 PM   #14
OlePhu
Oldskool
OlePhu's Avatar
Drives: 2013 Camaro LS
so, would these work on a 2013 Camaro LFX with 18" wheels. I just got some 18" aluminum wheels off a 2015 or would they need to be 20" rims to work?
OlePhu is offline   Reply With Quote
