Drives: 2013 1LT RS Camaro Join Date: Apr 2016
Service battery chargeing system
Service battery chargeing system came up in the information window on the dash when I started the car after getting out of work to day. It stared right up like it always does. I noticed that the little red battery icon was on also. I turned off the radio and brought up the battery voltage window in the info center. It was reading between 13.1-13.3 volts while the car was running during my 15 mile ride home. Stopped to get gas and it started right back up. No service battery chargeing system this time, but the red battery icon was still on. I still have the stock battery from when I bought the car in April of '13. Is this my battery dying or my alternator going bad? Has anyone else had this happen? Thanks.
![]() Drives: 2015 2LT SW RS A6 Join Date: Feb 2016
Run by autozone or a parts place and let them test the battery and alternator they can tell you if either is bad
![]() Drives: 2015 Camaro LT Join Date: Sep 2016
If it was the alternator, it would seem that 15 miles would be a long way to drive with just battery power. I would also expect that the performance of the vehicle would degrade as you went along. It probably is a battery problem. It does have a few years on it, and since your car sits all winter too, its probably stressed out. Just my opinion though.
#4 | |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
Thanks guys!
#6 |
So Kenny did you figure out if it was the battery or alternator or is it something else
#7 |
Don't leave us hanging .
I'm still on the stock battery on my 12 . Seems to be doing great so far .
#8 | |
[COTW 4/13/15]
#9 |
Ok, well the battery icon went off the next morning and has staid off and the service notice hasn't come back on.. i don't think it's the alternator because the car is running fine still. I think the battery is getting old/low. Yesterday when I got to work, I turned the motor off and turned the dome light on messed with my phone and a buddy came up and talked to him for a minute. Probibly less than 5 mins total with the radio and the dome light on. Musta just dragged it down enough to put the warning up and the icon on. It was off this morning. Not to jack my own thread, got new rear tires today. Nitto motivos 275/40/20. Hope they last longer than the perellis did.
#10 |
Saturday when I was at Dyno Days, while they were tieing her down and wiring her up, they had the motor off and power on. After the pull, they said the battery light was on and the service battery chargeing system notice came up again. I told them it happened the other day and went off. The did a quick voltage check and said the alternator was making good voltage. So it looks like the battery is on the way out.
