04-28-2017, 07:07 AM | #1 |
Drives: 2014 Camaro 2LT Deep Magenta Join Date: Apr 2015
14 2LT Manual Bind?
Hey guys, my 14 2LT has an issue or if it is "normal" based on doing a little bit of the search feature...bout the AY6
Whenever im idle, neutral... I push the clutch all way to the floor and attempt to switch to first. Rarely, it binds and won't go into 1st it moves over a little bit.. but doesn't fully engadge.. So i have to rinse and repeat and it'll work the 2nd time.. Has this been addressed/issue before? |
05-08-2017, 09:15 AM | #2 |
Drives: 2014 Camaro Join Date: May 2014
I think the owners manual even calls the situation out (and basically says to deal with it... double clutch and move on). However, I will say, since changing out my fluid a few weeks ago (while doing a few other things... new shifter and clutch primarily) that it hasn't happened. However, given that I did change my shifter and clutch at the same time, I can't 100% say that the fluid alone is to blame.
05-08-2017, 09:28 AM | #3 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
I still have this happen every now and then, and I've already swapped my fluid for mobil1 gear oil.
I usually have to do a quick pull down to second, then back up and it hits. The syncros seem weird on this trans.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-09-2017, 08:18 AM | #4 |
Thanks for the comments, i will go ahead and just drive it as it is. I will probably swap fluids whenever all the warranties are shot.
05-09-2017, 09:00 AM | #5 |
I recommend doing the trans and diff fluids ASAP. The stuff that comes out is disgusting, and it's a very easy DIY
05-09-2017, 11:51 AM | #6 | |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
05-09-2017, 09:10 PM | #7 |
Drives: 2015 1LS Join Date: Jul 2015
05-10-2017, 08:50 AM | #8 |
I use the same thing as in the diff. Mobil 1 75-90 gear oil. I recommend just doing both at the same time since it's the same fluid.
