![]() Drives: 2015 camaro Z/28 Join Date: Apr 2015
Without tune
Going to install American racing header and off road pipe in my garage.my question is the tuner shop about 20 miles from my house and want to drive my car there.would it hurt the motor driving it to the shop that far?
Black 2015 camaro z/28 #445 with ac
I drove my ss for about 2 weeks without a tune after installing long tube headers and 3" back to my npp cans. you will get a delayed response o2 signal code because the they are moved farther down the exhaust but will be fine, run fine just not to its full potential.
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
On my 2010 2ss i put headers on in 2009 and to this day have not done a tune, on my 2014 Z/28 have headers on it for the last 2+ years with no tune, and i track that car all the time
![]() Drives: Z/28 Join Date: Oct 2015
Same setup here. Been about 5k miles both track ( 4 events ) and street, no tune and I don't plan on getting a tune.
![]() Drives: 15 Z/28 Join Date: Jun 2014
No tune on mine, occasionally its a little stinky but no issues otherwise except for the check engine light.
#6 |
![]() Drives: 2015 Camaro Z/28 Join Date: Nov 2016
No Tune No Check Engine Light.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
No tune but occasionally an SES light for delayed response 02 sensor
#8 |
![]() Drives: 2015 Z28 Camaro Join Date: Nov 2016
You guys should all get your Z tuned. There is more power to be picked up with the tune then you will ever get with longtube headers.
#9 |
There is a way to fix the 02 sensor light, need to get some 02 extenders, that will fix it, no more light, there like $12 a set, and move the sensor out of the flame so they run cooler, that will fix it.
#10 |
#11 |
I am using Big Daddys o2 simulators work perfect angle bent with a ceramic liner inside.
#12 |
#13 |
my front 02 sensors will occasionally give a slow response code. I may have to replace them. I replaced them after the engine failure.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Yes...you will be fine driving it till you get your tune.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
