Old 04-29-2017, 09:31 PM   #1
KerseySS
Joey
KerseySS's Avatar
Drives: 2011 Camaro 2SS/RS L99 Cyber Grey
2011 l99 oil cooler leak
Is it common for the oil cooler lines to leak. I think my return line is leaking.
2011 Cyber Grey L99 SS/RS- 3.91 Gear
MRR 228 Wheels-Hurst shifter/base plate
LT Headers no CATS-Magnaflow 16582 Axle Back
RoboFab intake-Dyno Steve tune
ZL1 Rocker Panels-SLP Splitter
Lowered on Phastek springs
Pray Performance ported TB
Last edited by KerseySS; 04-30-2017 at 08:00 PM. Reason: Is it common for the oil cooler lines to leak
KerseySS is offline   Reply With Quote
Old 04-30-2017, 07:39 PM   #2
Jagrocksmi
Jagrocksmi's Avatar
Drives: 2010 Camaro SS
From my research it is pretty common. I have a 2010 L99 and mine is leaking too. I am just going to upgrade to an ADM trans cooler and replace the lines. It makes a good excuse to upgrade.
Jagrocksmi is offline   Reply With Quote
Old 04-30-2017, 07:54 PM   #3
KerseySS
Joey
KerseySS's Avatar
I think I'll do the same, I think its my trans cooler lines that are leaking. I'm going to put it on the lift tomorrow and see what's going on. It looks like I have a fine coating of oil on the bottom of my radiator as well. Hopefully it's nothing serious. Thank you for the response.
Sent from my VS985 4G using Tapatalk
Old 05-01-2017, 04:43 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
ADM cooler FTW. I actually upgraded the cooler with the larger B&M cooler. Stock kit is fine if you don't race...
-Don
747 RWHP 794 RWTQ
Old 05-10-2017, 06:40 AM   #5
myold88
myold88's Avatar
My 10 SS L99 had a couple of leaks when new. This oil cooler line plus the engine
oil pan. Both very common on the early Camaros. Both repaired under warranty
so I got lucky.
