Old 04-30-2017, 10:05 AM   #1
Dwright
Drives: 2011 Camaro 2ss
720 rwhp, but disappointed
Car build is finally done. 408 ci fully forged with lsa blower seems to be maxed out at 15 lbs. of boost. We put a 28% overdrive pulley (lower) and 2.5 upper along with E85 and the car puts down 718hp and 772 max torque. Car seams to want more air. On stock pulley without E85 it put down 641hp and 652 torque at 5900 rpm, now its max hp is at 5700 rpm with the upgrades. Tuner thinks the blower is maxed out. Just wondering our guys thoughts
Dwright is offline   Reply With Quote
Old 04-30-2017, 10:21 AM   #2
jrhagen
Banned
Drives: Camaro
That sounds about right. I have 376, LSA blower, 2.5 upper, 9.5 lower, gt9 cam, meth, 15 lbs boost and make 740/730.
jrhagen is offline   Reply With Quote
Old 04-30-2017, 01:03 PM   #3
bayarea408
bayarea408's Avatar
Drives: T
port that thing. Synergy motorsports does a lot of LSA port jobs, real high quality jobs. That might be the extra flow it needs.
bayarea408 is offline   Reply With Quote
Old 04-30-2017, 01:12 PM   #4
avido
Drives: camaro ss\rs
What cam do you have?
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
avido is offline   Reply With Quote
Old 04-30-2017, 01:30 PM   #5
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Time for a upgrade maybe twins or something similar to procharger
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 04-30-2017, 01:38 PM   #6
bayarea408
bayarea408's Avatar
Drives: T
seriously, a forged 408 with a centri or twins would be insane.
Old 04-30-2017, 01:44 PM   #7
Ls1408cp
Drives: 14 1le turbo
Or have the blower ported with a 102tb
2014 1LE 2SS/RS
Huron Speed turbo kit
Ls1408cp is offline   Reply With Quote
Old 04-30-2017, 01:57 PM   #8
avido
I'd like to get the 102tb but too many issues.portig the snout will give some solid gains.
Old 04-30-2017, 01:58 PM   #9
Moreair1
Moreair1's Avatar
I'm not sure the cost to port the Lsa blower but with the set up you have built I believe you will be disappointed, some articles I have read they had marginal gain to where others have gained 50 hp, you could gain more than that but imo you built that motor to probably make a heck if a lot more
Old 04-30-2017, 03:03 PM   #10
Dwright
I thought about porting but between that and the 102 mm tb. I think I am just going to a big 3.3 whipple or 4.3 Ken bell this winter. The cam is a stage 2 bmr blower cam. Any gains with porting will be somewhat minimal. The Motor is an 8:3:1 compression ratio it was built for boost and lots of it.
Old 04-30-2017, 04:16 PM   #11
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Solid numbers but if your not happy I'd up the compression at least a full point.
The motor might respond well to a bigger intake and tb.
Trackman is offline   Reply With Quote
Old 04-30-2017, 04:42 PM   #12
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
Yea, 8.3-1 compression with a 1.9 LSA blower is going to give you too low of a max. Now if you had a blower or turbos that could throw plenty of air like 22-24 psi at it, then great.
2013 A6 ZL1
Redlineviper is offline   Reply With Quote
Old 04-30-2017, 05:03 PM   #13
AGP Turbo
Drives: All things Turbocharged
I'll be expecting your call monday
Tough situation on those low CR postons. LSX block would be the only way to take advantage of the 30+psi those pistons are good for. Given that you are on E85, I would have built that around 10.5. Way more efficient. I'd bite the bullet and change them.
AGP Turbo is offline   Reply With Quote
Old 04-30-2017, 07:00 PM   #14
Dwright
So I will give it some thought. The Motor supposedly is built to handle up to 1350 rwhp without any issue, I have all the other supporting mods built to handle 1200hp. Decisions/decisions. I will talk to the builder but not sure about piaton swap but may be the cheapest option
