Old 05-01-2017, 01:27 AM   #1
Fatboys1l-e
Drives: 2015 camaro 1l-e
Rear end
Anyone with a 5th gen 1le have any problem with the rear end floating
Fatboys1l-e is offline   Reply With Quote
Old 05-01-2017, 09:13 AM   #2
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
Can you give some more detail about your problem?
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 05-01-2017, 10:05 AM   #3
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Need more info....can't imagine you're referring to a bouncy feeling, unless your rear shocks are shot. I've always found the rear to feel planted as hell, before and after the CO swap.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 05-01-2017, 10:12 AM   #4
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Was waitin for other peeps to chime in...here is my q...did you do ANY rear suspension work recently? If so peeps forget about the need to "TIME" the rear suspension bolts....ie the car needs to be put back together and then on flat level surface with all 4 tires on the ground, ramps wat ever...the rear bolts need to be slightly loosened(all at the same time!) so the suspension can "settle". Then re-tighten to spec...
Found this out the hard way when replacing the front bearings on a Volvo XC-90...the front end danced all over and when braking would try to dart to the right...all I did was the above(on the front end tho) and prob SOLVED! And this was after I had it re-aligned...good luck...
Old 05-03-2017, 12:25 PM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Cradle Bushings in your Future?
Old 05-04-2017, 01:14 AM   #6
Galaxy_Stranger
Drives: Black 2013 2SS LS3 1LE
Are you talking about it getting slippery when you're tearing ass?
It's very difficult for me to break it loose on new Eagle F1s, but when they start to wear, they can get slippery in bone-dry weather just turning corners.
Sometimes, when accelerating on the feeder so as not to pull a "frogger", you can feel torque hop in the rear end from tire to tire, back and forth. Then it settles when you get into a sane gear.
Is that what you're talking about? Again - slick tires in the rear means you need new tires.
Galaxy_Stranger is offline   Reply With Quote
Old 05-04-2017, 09:07 AM   #7
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
Everyone here is just stabbing at the wind. We need some more details other than "floating". Last time I checked, and that was a few minutes ago, my car is still firmly on the ground and I haven't tied it down. It's been called a dirigible before, so maybe I just haven't seen the floating yet.
My thoughts on some things:
  • Driving Nannies: If I'm that far out of shape on the street, something has gone terribly wrong and by all means Mr. Computer man, come and get me.
  • G2s: Rock throwing is like like a tramp stamp; although problematic, it's a sign of good things to come.
Billy10mm is offline   Reply With Quote
Old 05-04-2017, 10:51 AM   #8
Olddudesrule
Resident nomad
It's been five days, I guess the floating couldn't have been that bad....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
Old 05-04-2017, 01:01 PM   #9
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Or it was so bad that he floated away.......
gajagfan is offline   Reply With Quote
Old 05-04-2017, 02:00 PM   #10
Shoe2ss
Shoe2ss's Avatar
Drives: 2014 2ssrs
my ass end floats around when I hold that traction control down for 10 sec
2014 SS/RS blackwing CAI. LTH. 3inch X pipe exhaust to NPP mufflers. SLP TVS 2300. 1LE strut tower brace. 5.1 short throw shifter. BMR trailing arms. poly cradle mount bushings. 559HP/543TQ
Shoe2ss is offline   Reply With Quote
Old 05-09-2017, 01:57 PM   #11
markgws6
markgws6's Avatar
Drives: 2019 Chevy Equinox Premier AWD
I put on a new set of MPSS tires on the rears only, and I had a "floating" rear end feeling too. :-)
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43)
markgws6 is offline   Reply With Quote
Old 05-10-2017, 09:12 PM   #12
paul84043
paul84043's Avatar
Drives: 2015 Camaro 2SS RS 1LE
None here. solid as a rock.
paul84043 is offline   Reply With Quote
