Old 05-01-2017, 10:45 PM   #1
scv_guy
scv_guy's Avatar
Drives: 2010 Camaro SS
Need some advice!!
I'm getting ready to take my car to the track for the first time. You can see my mod in the sig.
My question is i have an LNC-2000 2 step set to 3k and 15* timing retard but the car will start pushing through the brakes. How can I get the brakes to hold?
I can stall to 2800, but it's not making any boost.
Any suggestions besides a looser converter??
scv_guy is offline   Reply With Quote
Old 05-01-2017, 11:56 PM   #2
BrainleSS
Working on my 2nd one!
BrainleSS's Avatar
Drives: Camaro
Transbrake
[SIGPIC][/SIGPIC]
BrainleSS is offline   Reply With Quote
Old 05-02-2017, 12:05 AM   #3
scv_guy
scv_guy's Avatar
Originally Posted by BrainleSS View Post
Transbrake
I wish! I'm a 6L80
Old 05-02-2017, 01:56 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
What has it run at the track and what power does it make?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-02-2017, 01:59 PM   #5
scv_guy
scv_guy's Avatar
It has gone 10.90 132mph 1.65 60'
Makes 750whp
Old 05-05-2017, 07:14 PM   #6
WatchThis
WatchThis's Avatar
Drives: 2010 Chevy Camaro 2SS/RS
I wish I could help but I'm actually in for some help on this also. Got a very similar setup as you and once I stall up around the 2800-3000rpm range, it starts to push thru the brakes. Just from the mph though, your car has a lot more in it for sure. Figured I'd bump this up and see what happens.
2010 Camaro 2SS
2010 Jeep Wrangler
2014 Ducati 1199 Panigale S
WatchThis is offline   Reply With Quote
Old 05-08-2017, 06:56 PM   #7
scv_guy
scv_guy's Avatar
Bump...
Old 05-08-2017, 08:00 PM   #8
jrhagen
Banned
Drives: Camaro
Wouldn't have that problem with a supercharger. However, a friend had that problem with his MOPAR. He had to get an upgraded brake booster that will hold with less vacuum. You might want to check into that.
jrhagen is offline   Reply With Quote
Old 05-08-2017, 10:06 PM   #9
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Wow you should be able to stage with higher rpm on a 3400 stall. I'm staging over 3000 with a 3000 stall and foot braking.
With your HP and mph you should be mid to low 10s.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
