Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 05-02-2017, 02:27 PM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Monster Billet bearing support & OEM Throwout Bearing
Brand new just received it yesterday. Haven't even started the car with it on yet. My last slave failed, so I purchased a new OEM SKF bearing by itself from a bearing vendor thinking that was the only issue and the slave itself was okay. and it ended being the entire slave. So now I'm going to a RAM unit.
I installed this throwout bearing with my slave, bolted up the transmission, and pumped the clutch petal a few times and the pedal stuck to the floor. I still got leaking brake fluid from the bellhousing like before. That's all I did with it.
You usually have to buy the bearing together with the slave which is $429 from GM. if you just need a replacement bearing minus the whole slave cylinder this is for you.
$40 shipped.
Also selling the Monster Billet bearing support. About 6k miles on it. The finished is scratched up on the inside because of previous slave failure, but it does not effect the functionality of piece at all. Will post pictures soon.
$45 shipped
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 04-08-2019, 06:11 PM   #2
Zl1dad
Drives: 2013 zl1
$40 shipped.
$45 shipped
Is this throw out bearing available still?
Sent from my HTC 10 using Tapatalk
Zl1dad is offline   Reply With Quote
Old 04-08-2019, 06:12 PM   #3
Zl1dad
Drives: 2013 zl1
If not do you have a skf part number?
Old 04-08-2019, 06:31 PM   #4
Zl1dad
Drives: 2013 zl1
I found part number but where did you purchase from, not finding anything online.
