Old 05-03-2017, 12:59 PM   #1
13BRM2SSRS
13BRM2SSRS's Avatar
Drives: 13 Camaro 2SS Vert L99
Hard water
Thought I would share this insight! I would get what looked like polish residue around the edges of shark fin antenna on the trunk lid which on dark paint looked like crap. I determined it was not polish residue and thought it was a paint defect. Under warranty the dealer had paint and body shop "fix it" and I assumed they did some paint touchup. Some time later it was back again. I decided to remove the antenna and check it our myself. Turns out it was just hard water build up. I removed most of it with CLR and since I was doing paint correction anyway the DA Polisher cleaned the rest up. I finished it off with a ceramic coating which turned out awesome!
If you don't know, the antenna has a small rubber seal that covers the hole through the trunk but water can sit under the rest of the antenna housing and it weeps out around the edges and dries which causes hard water deposits.
Black GFX / Dynatech Supermaxx LT Headers / FR Black Chrome ZL1 Replicas 275/315 / RDP Tune / CAI / VMAX TB / MBRP SS Catback / Gtechniq CSL & EXOV3 / VTC / RX Catch Can / Valentine 1 / Halo DRL / LED Fogs
13BRM2SSRS is offline   Reply With Quote
Old 05-03-2017, 09:03 PM   #2
18LTLoveIt
18LTLoveIt's Avatar
Drives: 2018 Hyper Blue LT RS
Yupp hard water here in Phx too. I usually wash mine 2 times a year. I do the back 1/2, rinse & dry & the front 1/2 rinse & dry. White is easy to take care of & it doesn't rain much here when it's out of the garage for the spring until Nov.
18LTLoveIt is offline   Reply With Quote
