Drives: 2013 1LE Join Date: Jan 2013
DSE and Ohlins = first class
Hey guys,
I've had my car on jack stands since November. I had put it away for winter with planned suspension upgrades but I've been extremely busy with my job and family commitments but finally today I just about completely wrapped up what I started working on in December. I've installed all of the Detroit Speed suspension pieces except for the JRI/DSE coilovers. So, it's lower control arms, toe rods, trailing arms, subframe bushings, anti-roll bars front and rear, links, caster kit, wheels studs, and motor mounts. I've also installed the Ohlins road and track coilovers paired with a set of Ground Control Camber plates. The spring rate is just about 400lbs (70 N/mm) front and 628LBS (110 N/mm) rear. I've got the single adjustment valving 12 clicks from full stiff front and 14 clicks on the rear. This is based on the Ohlins recommended setting for street driving. I seriously need a proper alignment but I managed to "string up" the car with some jack stands and I made some basic adjustments for Camber and Toe. Interestingly enough I noticed that I was only about 1.5mm+/- from 660MM ride height (bottom of wheel to top of fender) based on the Ohlins suggested spring preload adjustment during assembly. So I set the ride height to 660mm and this was encouraging as I had read Peter from JPSS suggest this setting as a good place to be on our cars. I don't have another day off until Monday and I'm scheduled for an alignment at a well known race team shop outside of Boston then. I took the car out for about a 10 miles drive today so I could listen for possible loose items and check on my work. So far no issues. It was quiet, stiffer, not uncomfortable but the ride was a lot more precise and the Ohlins do a fantastic job of soaking up the irregularities on the road. I didn't push the car beyond the legal speed limits but the car behavior has certainly changed. Its feels great to have better sense of what the tires are doing and the whole car responds so much more quicker to my inputs. Overall I very happy with the results, I'll be heading to New Hampshire motor speedway on the 13th so I'll really get a chance to test the car and hopefully find a higher limit of performance. I've never bought anything from Peter at JPSS but I want to say "thank you" to him because whenever I had an issue over the past few months I was able to come to this forum and search for an answer and it was almost always something that he has already addressed. So that was a big help to me with my limited time. I'll try to follow up on this post with some more details after the alignment and the upcoming track days. Cheers, Abdi |
![]() ![]() Drives: 2015 Camaro SS/1LE Join Date: May 2015
Sounds pretty nice! I'm looking forward to your followups.
2015 2SS/1LE/RECARO/NPP/RS/NAV
Awesome. Subscribed. I am very interested in the Ohlins but there is very little feedback on them for the Camaro platform.
![]() ![]() ![]() ![]() Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
I've used Ohlins products multiple times on motorcycles. They are arguably the highest quality suspension bits one can get for a motorcycle. I would expect no difference in their 4-wheeled offerings and wouldn't hesitate to purchase.
My thoughts on some things:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Did the front strut to tire clearance increase with these coilovers vs the OE struts?
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather |
#6 | |
On my installation I was acutely focused on this as I wanted to gain both SAI, clearance for a future 10.5 wheel with 305 tire, and greater range of camber adjustability. Without camber plates this would be impossible. Yes. Last night on the 10" ZL1\1LE wheel with 295 Trofeo tire I measured camber at -2.7 with a digital angle finder with about 12mm (1/2") of clearance from the front strut to tire. I would highly suggest camber plates for those reasons alone. I also pretty certain that I've gained caster but I'll confirm that Monday on the alignment rack. Based on my measurements I'm thinking I'll get away with 10.5 front wheel with a +23mm offset. I'll lose about 3mm of clearance. Wheels are next on my list. Last edited by Abdi; 05-05-2017 at 02:25 PM. Reason: spelling |
#7 | |
I'm more or less decided on the Ohlins for the Camaro, the R&T should be just about perfect for my environment. Bumpy backroads, bumpy tracks (except COTA, but that is developing some bumps as well). My favorite little home track is H2R, and it is very bumpy. |
#8 |
![]() ![]() ![]() ![]() Drives: 2013 Camaro 1LE 1SS Join Date: Aug 2012
Do you have any pictures of the Ohlins amd how the car sits now?
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
#9 |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
#11 | |
When I bought the Ohlins I was only the second guy to actually take delivery in the USA. I am also the first with the GC plates so I'm sure I've taken the risk of finding potential pitfalls but these are both companies that I've purchased from multiple times before and never been disappointed. |
#12 | |
http://www.bcforged-na.com/monoblock/rz05/ |
#13 | |
#14 |
10.5 +26 ET front.
11.0 +43 ET rear. All wheels from BC are custom ordered. I worked with Jonathan DeHate from BC North America on this. I was very happy with the help and the price. I realize these are not made in the USA but they are both JWL and VIA certified in Japan. I really wanted Forgeline or HRE but I can't swing the price no matter how I look at it. I want to keep the rear the same as it currently sits. The front will be about .25" further inboard, and .25" on the outboard of the fender. I think I'll be happy with that look. With camber plates in the front this should look pretty good. Looks are not my biggest priority but I do take it into consideration. I have an Aero Sport Concepts kit to install and I think it' will compliment the front wheel nicely. Abdi Last edited by Abdi; 05-08-2017 at 11:40 AM. Reason: correction to numbers |
