Old 05-04-2017, 11:40 PM   #1
Cosa
Drives: 2015 Camaro LS
ZL1 Replica Wheels Question
The top picture is my car , The others is what I want My car to look like.
I just got out of highschool so I dont know much about stuff like this , I do have a V6 Camaro LS.
Does any one know Which Size ZL1 Wheel(s) I need to get to achieve this look?
Cosa is offline   Reply With Quote
Old 05-05-2017, 06:33 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
Fronts are 20x10", +23 mm offset; rears are 20x11", +43 mm offset. If you're buying replicas they will be available in these sizes/offsets. You can also consider 20x10" with +35 mm offset for a square setup and this way you can rotate tires on all four corners, if you like to be able to.
KillboyPowerhead is offline   Reply With Quote
Old 05-05-2017, 09:15 AM   #3
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
I went with 20x9 on all 4 corners of my 1LS, 275/40/20s. Allows me to rotate and I like the look.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 05-05-2017, 04:20 PM   #4
Cosa
Do you reccomend gloss black or flat black ?
Old 05-05-2017, 04:52 PM   #5
GodWentPunk
GodWentPunk's Avatar
Drives: 2015 2SS White Convertible CE/INDY
check out Factory Reproductions to see their options. With gloss, there is more work involved to keep them glossy... matte is for the lazy guy
My eyes are terrible but I think the first black car might have actual ZL1s which will have the word "Camaro" stamped on the outside lip.
good luck.
joe...
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
GodWentPunk is offline   Reply With Quote
Old 05-05-2017, 10:53 PM   #6
KillboyPowerhead
Drives: 2015 Z/22
All personal taste, but generally I prefer glossy over flat - just looks nicer, flashier, and I like shiny stuff. I think gloss would go better with a factory-painted black car; likewise flat black wheels would go better if the car was flat black too, but again that's just me.
Old 05-05-2017, 11:00 PM   #7
Ryanbabz71
Ryanbabz71's Avatar
I went 20x9 up front and 20x10 on the rears
Factory reproduction gloss black
Sent from my iPad using Tapatalk
Ryan
Old 05-08-2017, 11:25 PM   #8
Demon War Horse
War Horse Pilot
Demon War Horse's Avatar
Drives: 2017 NFG 1SS 1LE
20X10 and 20X11 rears. No rubbing and lowered 1" overall.
COTW 09/07/2015 - 2014 AGM 2SS/RS - RIP 6/01/17
2017 Nightfall Gray Metallic 1SS 1LE Born 5/17/17 - Click Sig Pic below for for Demon War Horse 02 Build Thread
SigPic by Hazman
Demon War Horse is offline   Reply With Quote
Old 05-09-2017, 12:01 PM   #9
Roasstum1
EbonyCamaro
Roasstum1's Avatar
Drives: Black SS 14
Warhorse +23 or +35 on the front offset? I'm lowered 1" also and have been thinking of upgrading from stock ss rims.
Roasstum1 is offline   Reply With Quote
Old 05-09-2017, 01:00 PM   #10
UBB
UBB's Avatar
Drives: 2018 ZL1
I'm 20X10 all around and lowered 1"
UBB is offline   Reply With Quote
Old 05-09-2017, 02:27 PM   #11
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
Nice. I run the same setup with a +23 offset all around. Lowered 1". I'm running 285-35-20's all around. Rubbed up front when I had 275-40-20's autocrossing.
SS PANTHER is offline   Reply With Quote
Old 05-09-2017, 03:37 PM   #12
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
Same as above. 1" lowered on BMR springs, 20x10 all the way around with a +23 offset with 285/35's.
In the three pics you posted, the second one down probably has the LG ZR28's if they're not factory wheels. There's a slight difference between the LG's and the Factory Reproduction style (what's in the 3rd pic) where the spoke meets the outer portion of the wheel.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared
blakjak55 is offline   Reply With Quote
Old 05-09-2017, 03:58 PM   #13
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
I run 20x9 with a 275/40/20 on all four corners - the ability to rotate is wonderful, and the additional rubber up front reduces some of the understeer bias the car has in it.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 05-09-2017, 04:12 PM   #14
Demon War Horse
War Horse Pilot
23 I believe. Stock ZL1 offset front and rear. 1" hotchkiss drop.
SigPic by Hazman
