Old 05-06-2017, 09:10 AM   #1
oobergoober
Drives: 2013 1LT rs
Installed gauge cluster, car dead, but battery good
I posted this over in the problems thread, but thought since it occurred after I installed a 4 gauge cluster, maybe someone over here might know something...
I just installed a 4 gauge cluster in my '13 1LT. I left the stereo on, and got distracted for a bit. Came back, car was dead.
I used a li ion jump pack to jump her, and she fired right up, but once the jumper pack was off, nada, nothing.
So I took the battery into a parts store, they said the battery was good, just needed charging, so they gave her a full charge. Reinstalled the battery, and she's still completely dead. I put the jumper pack back on, and she fired up immediately. Removed the jumper pack again, dead.
What the heck could be causing this? I verified the battery was good--14.7v with a voltmeter. Could I have hosed up something in the primary electrical system just installing gauges?
Any help appreciated.
Thanks!
oobergoober is offline   Reply With Quote
Old 05-06-2017, 10:08 AM   #2
Leo72793
Drives: 2011 2SS/RS
Thanks!
think it narrows it down to the battery. a jump pack is basically an external battery. get a new one.. if it works good if not make sure the positive at the post in the engine bay is good connection.
Leo72793 is offline   Reply With Quote
Old 05-06-2017, 10:55 AM   #3
oobergoober
Drives: 2013 1LT rs
O'reilly said she was good, but I don't know if they did the deep load test on her.
I took the battery out of the trunk, and hooked her up under the hood using jumper cables. Battery was weak, but at least she finally caught & started.
Are there any relays in the primary electrical system between the battery & the ignition that could have gone bad?
Taking the battery to another parts store now to see what the verdict is. Sure would be nice if it were just something simple like a bad battery...
Old 05-06-2017, 12:03 PM   #4
oobergoober
Drives: 2013 1LT rs
Autozone said battery was good too. They suggested driving it in & letting them do a full test. Jumped her with the battery pack & drove her back (only 2 mi). Their computer gave a "cannot sense engine rpm" error when they told me to rev it. She would only rev to about 3100 rpm. Drove home, uninstalled the gauges/DIY harness, still dead.
Old 05-07-2017, 04:09 AM   #5
cohocarl
cohocarl's Avatar
Drives: 2015 1LS
That is odd...
I know this is a long shot, but when installing the gauge cluster, the positive wire leading from the battery wasn't compromised by chance was it???, or the insulation on it?
I was just thinking if the bat is in fact good, and your ground strap is also good....if you jumped it from inside the engine compartment and it starts, but without jump starting it won't start....I said it's a long shot, but that does sound odd.
cohocarl is offline   Reply With Quote
Old 05-07-2017, 07:45 AM   #6
oobergoober
Drives: 2013 1LT rs
Originally Posted by cohocarl View Post
That is odd...
When I was fishing the power wire thru to the console, I DID jimmy the power cable around a bit. A LITTLE BIT, as in maybe 1"??? The insulation was still soft/rubbery, and the cable didn't feel brittle.
The fact that it will only rev to about 3K, and that the computer can't detect RPM would indicate something more severe than a damaged power cable tho, wouldn't it?
Overnight I was having nightmares of taking it to a stealership, and being told I'd fried the computer, and it was going to be $2K to repair...
Old 05-07-2017, 07:52 AM   #7
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Just swap the Battery. Do you have a friend or another vehicle you could borrow the battery from and try it?
The Bird is the word!
Old 05-07-2017, 09:19 AM   #8
oobergoober
Drives: 2013 1LT rs
Battery isn't the problem. Verified 3 times.
Old 05-07-2017, 10:16 AM   #9
Angrybird 12
If it is an automatic in park or neutral it will not rev any higher than that. Did it rev higher when you drove it?
Old 05-07-2017, 10:16 AM   #10
Angrybird 12
Did they do a load test on it after they charged it?
Old 05-07-2017, 12:28 PM   #11
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Short story, we sold a mylink to a guy, and they did the install, all went well, 3 months later they called up and said the face plat was bad, car was fine radio was fine but the screen did not get bright, we worked out a deal to replace the face plate, and sent one to them, did not here back for 2 weeks how things where going, then we get a phone call, the did not need the new face plate, we asked why? was told and i " seams that one of the things they tested before the call about the face plate in the first place was the battery, they where told the battery is fine only run down all it needs is a charge" whell when we sent the new face plate car was pulled out to change the face plate but this time it did not start at all, see it dyed all the way this time, and to me it sounds like what yours will do any day now.
ITS your battery..........
Old 05-07-2017, 01:08 PM   #12
oobergoober
Drives: 2013 1LT rs
Yes. Said it was putting out 700 cca's, batt was rated for 720 I believe. They said that was well within acceptable range.
Old 05-07-2017, 02:05 PM   #13
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
You said you have a volt meter? Connect the battery and check the volts. If it's zero you caused a short with whatever you did!
Rainbow1616 is offline   Reply With Quote
Old 05-07-2017, 02:47 PM   #14
oobergoober
Drives: 2013 1LT rs
Well, 1 $160 battery later....problem still there. Had to use the jump pack to leave the store with new battery installed.
On the drive home, batt voltage was constant between 14.7 & 14.8v. New issue: Mylink stereo turns on & off intermittently now...
