Old 10-27-2009, 11:49 PM   #1
general23cmp
Drives: 2010 RS SS
tuning required CAI and exhaust
Ok, I understand that these cars really wake up when they are tuned properly, and that these effects are really noticable when the car has bolt-ons like CAI and exhaust; however, most people do not have their cars tuned, ever.
So, what are the possible damages that a car might encounter when doing these bolt-ons with no tune? Will the car not tweak itself in the ECU to run without damaging itself? I know it will not be as efficient as with a tune, but could it really harm itself if a teenager decides he wants to put a catback and a CAI for some extra HP and sound? I'm not talking about serious mods like a SC or cam, either.
general23cmp is offline   Reply With Quote
Old 10-27-2009, 11:54 PM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
If you are not looking for the last HP i don't think there is a problem, Get the CAI you like the best and find all the info on it and the headers you can, And then buy it if it works for you.
Old 10-28-2009, 12:00 AM   #3
GQ4Life
Drives: 2010 Camaro SS LS3
well if mods add good amount of HP then there is chance car can go lean and that bad for engine.. but doubt it with just exhaust and CAI..
someone with CAI and exhaust that got car dynoed needs to chime in with their untune afr..
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 10-28-2009, 12:07 AM   #4
2SSRS@Gen5diy
I think that tag your it has his car set up that way.
Old 10-28-2009, 02:05 AM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There were a few CAI's that began to have a small amount of knock, according to the CAI test that Jannety did. I think one of these with a good flowing exhaust could exacerbate that.
Old 10-28-2009, 07:48 AM   #6
EAkrish
Scout Sniping
EAkrish's Avatar
Drives: 2010 Ford F150 Lariat SuperCrew
Send a message via AIM to EAkrish
Tag's car is insane, he also just found out about the cel reset. He is running h/I/e combo with no tune and his car is running amazing! I have intake, down pipes, otr intake, full 3" exhaust and a ported tb with a street tune and my car is running amazing also. It's up to you. I spent about 1700 for everything! I think I am cheap but like I said, the car runs perfect
Eric
Previous Car:1SS/CGM 6MT w/ Sunroof & FACTORY BLUETOOTH!!!: New Era OTR, Steeda Short Shifter, Ported TB, Stg 2 ported intake manifold, Fasterproms, Poor man down pipes, MBRP 3" Exhaust!!!
Now I drive a F150 Supercrew
EAkrish is offline   Reply With Quote
Old 10-28-2009, 08:07 AM   #7
BOETIE
BOETIE's Avatar
Drives: 2010 2SS 6 Speed Man
Are you concerned about waranty issues ?...those are pretty major mods.
She's a Zaino Girl !
BOETIE is offline   Reply With Quote
Old 10-28-2009, 08:10 AM   #8
EAkrish
Scout Sniping
EAkrish's Avatar
I don't think anyone would consider these mods major. I have not cracked the motor at all. I know some people don't even think a cam is a major mod.
Eric
Old 10-28-2009, 08:34 AM   #9
BOETIE
BOETIE's Avatar
I talked with the service mgr when I ordered,he said he personally didnt care about mods,but he said if the zone rep shows up and if there is a car in the bay that has been modded,it has to be noted by the service man or he gets busted,I asked about exhaust,he said axle back is ok,in front is a gray area if the zone rep sees it....I have heard all the builders are getting picky.
It sounds like your car should be running very strong,has it been on the tread mill ?
Old 10-28-2009, 08:39 AM   #10
EAkrish
Scout Sniping
EAkrish's Avatar
Not as of yet, I have no time with nursing school and all. Soon though! It feels real strong butt dyno numbers
Eric
Old 10-28-2009, 09:08 AM   #11
BOETIE
BOETIE's Avatar
I like MBRP alot, they make very nice exhausts systems, I have one of their systems, I would like to hear a sound bite of that 3 inch....should rock !
Old 10-28-2009, 09:17 AM   #12
Silver Ice Man
Silver Ice Man's Avatar
Drives: 2014 2SS/RS Spring limited edition
I don't think you neeed to worry about getting leaned out from the bolt on mods, I am running the roto-fab CAI, and the Borla cat back set up on my camaro, and the exhaust tips are as black as night from exhaust soot. So that tells me she is running very rich.
I only have 6500 KMS on her right now, so the computer could still be running it in break in mode as well. Either way I will be giving vector motor sports a call in the spring for a tune, and hopefully dial in this car.
Just my .02
2014 2SS/RS, Spring Limited Edition...
Ask yourself.....when you turn on your car..... Does it return the favor.....
MODS: CIA cold air intake, Oil catch can, Dynatech LT Headers, Dynatech Power cats, Dynatech Cat back exhaust, Janetty racing tune, Vitesse throttle controller, Headlight and marker tint, more to follow....
Silver Ice Man is offline   Reply With Quote
Old 10-28-2009, 10:14 AM   #13
JANNETTYRACING
JANNETTYRACING's Avatar
Headers and exhaust will Not need tuning.
The Cold Air intake you choose may or may not need tuning, Most Do Not.
You can use the Cold air intake results as a guide, Lower Fuel Trims Mean either little or No tuning required.
Knock will learn out so Nothing to be worried about there.
These computers Constantly are adjusting to the conditions and they are tuned for max Power.
Once you get in to a Blower, Cam, Heads, Different Mass Air Flow Meter, Larger injectors, then Tuning Is Absolutely necessary.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-28-2009, 07:28 PM   #14
MoranoRacing
Drives: 2005 GTO, 1973 Camaro
You won't need a tune with an exhaust and cold air intake. If you want every bit of power then get a tune afterwards.
MoranoRacing is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 06:56 PM
LMR CAI, Longtube Headers, SLP exhaust sound clip! Late Model Racecraft Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 12-08-2012 09:02 AM
GMPP headers, exhaust, CAI add no POWER 1camaro70 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 87 10-03-2009 09:50 AM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
