Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 05-08-2017, 07:26 PM   #1
Zl1TopLess
Zl1TopLess's Avatar
Drives: 2013 Victory Red ZL1 M6 Vert
12" wide rear wheels On a ZL1
I want to run a 20x12 43 offset on the rear. The number seem to work but i was wondering if anyone else has run a 12 and what tire size did they use? I am thinking of 335/30/20 or some 345/30/20 like cup 2s.
2013 ZL1 M6
Roto Fab CAI, Kooks Long tube Headers with catless connection pipes, 90mm Ported throttle body to match ported supercharger snout. 2.55 upper pulley, Roto Fab intercooler tank, ID 850 injectors, 9.5 mm wires, Custom 93 octane tune. 600 whp. Hotchkis coils.
White Collar Grease Monkey
https://www.youtube.com/user/gjodexter
Zl1TopLess is offline   Reply With Quote
Old 05-08-2017, 07:28 PM   #2
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
Originally Posted by Zl1TopLess View Post
I want to run a 20x12 43 offset on the rear. The number seem to work but i was wondering if anyone else has run a 12 and what tire size did they use? I am thinking of 332/30/20 or some 345/30/20 like cup 2s.
Good luck finding 332/30/20 tires.
The wheel should fit fine depending on what tires you put on there, it could rub on the inner fender
2013 A6 ZL1
Redlineviper is offline   Reply With Quote
Old 05-08-2017, 07:54 PM   #3
Zl1TopLess
Zl1TopLess's Avatar
fixed
2013 ZL1 M6
Old 05-08-2017, 07:55 PM   #4
Zl1TopLess
Zl1TopLess's Avatar
Cup 2 345/30ZR20
(106Y) SL
180 AA A 2,094 lbs. 51 psi 7.2/32" 33 lbs. 11.5-12.5" 12" 13.8" 12.7" 28.2" 738 FR
From Tire Rack
2013 ZL1 M6
Old 05-09-2017, 10:42 AM   #5
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
I'm honestly not seeing a 12 inch wheel fitting very well without sticking wayyyy out side of the fender. If you do it, be sure to post pics because a Corvette size wheel/tire would look sick on our cars.
Can'tHave2MuchHP is offline   Reply With Quote
Old 05-09-2017, 10:50 AM   #6
Liquidity
Drives: 2015 Camaro Z/28
12' wheels would look really nice.
Liquidity is offline   Reply With Quote
Old 05-09-2017, 04:57 PM   #7
Zl1TopLess
Zl1TopLess's Avatar
So am i going to be the guinea pig? That's an expensive chance. But the numbers seem to all work and i have checked the clearances and its there. The front wheel is about 3 to 5 mm in and the rear is about 15 mm in from outer fender lip to rim face. with a 20x12 43 that's another 13 out, it will be close. I was also consider a 11.5 just to hit the min on a 335 tire. Whats the widest tire anyone has put on the 20x11 43 wheel? Was there any rubbing issues? Camber does come into play with these numbers.
2013 ZL1 M6
Old 05-09-2017, 09:06 PM   #8
Can'tHave2MuchHP
Drives: Fast
Honestly if you can find a local guy with a GS/Z06/ZR1 body style in C6 or C7 to unbolt his and mock them up on your ZL1 you'd be able to get an idea, those are be 20x12 with 59mm offset, bolt pattern should be the same. Not 100% sure it would work at all but it's worth a shot if you can.
I know a 11" wheel will stick out the same as a 12" wheel as the 12" just adds more on the inside. This is unventured territory.
Old 05-09-2017, 10:19 PM   #9
E. Bryant
Gearhead
E. Bryant's Avatar
Drives: 2012 ZL1
Here is my car with the OE Z28 wheels, 305/30R19 tires, and stock ride height:
As you can see, this wheel/tire fitment already sticks out past the fender lip. With a 26" tall tire, it doesn't rub, but I'd be concerned that a 28" tall tire would contact sheetmetal.
2012 Chevrolet Camaro ZL1 M6 - JRE 650 RWHP kit, AFCO heat exchanger, JPSS V4 aero, Z28 wheels for the twisties and Weld big-n-littles for the dragstrip.
11.193@128.13 in 515' DA
E. Bryant is offline   Reply With Quote
Old 05-09-2017, 10:37 PM   #10
VicV
Drives: 2012 Camaro ZL1 #1458
Does anyone know if a 315/35ZR/20 will work on the rears of a ZL1
VicV is offline   Reply With Quote
Old 05-10-2017, 11:04 AM   #11
Can'tHave2MuchHP
Drives: Fast
Yes those will absolutely work on OEM ZL1 wheels.
Old 05-11-2017, 07:47 AM   #12
Zl1TopLess
Zl1TopLess's Avatar
Z28 wheels have a different offset, i believe its,
F 19x11ET11 (25mm further out than ZL1/1LE wheels)
R 19x11.5ET26 (23mm further out than ZL1/1LE wheels)
2013 ZL1 M6
Old 05-11-2017, 07:53 AM   #13
Zl1TopLess
Zl1TopLess's Avatar
With a 20x12 43 offset, Thats plus 13 either way. The inside has room and it should make the outside flush or just under. I may just go wuth 11.5 43 offset to be safe. With that i can run a 345/30/20 cup 2 O.D. is 28.2 just under stock. They are on the narrow side of just 12.7 tread width. The wheel width minimum spec is 11.5.
2013 ZL1 M6
Old 05-17-2017, 11:49 AM   #14
Zl1TopLess
Zl1TopLess's Avatar
So I ordered VS02 in matte brushed bronze
20x10 23 offset front with 285/35/20 Cup 2
20x11.5 43 offset rear with 325/30/20 Cup 2
and now I wait 5-7 weeks.
2013 ZL1 M6
