When you get it back from a shop and need to go to another shop to get it done right.
That is some talented welding These are the finished pics. |
I couldn't believe it when I seen the cut outs where only tack welded on there
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
Holy smokes, that's some real butchered exhaust work there.
Not related to the obviously hammered on mid-pipe but 4th picture down you see your o2 sensors? On the driver side there 2, of them. The grey wiring sheath is for the primary O2 for B1S1 and below it at an obvious downward angle I can tell is the wideband. I'm not sure who installed the Bung for the wideband as it is an obvious oversight as when you put an o2 sensor on a downwards angle like that the condensation building in the exhaust will collect on the sensor and rott it out from the inside out. Always install o2 bungs at an upwards angle preferably 15* or so or else you'll experience premature sensor failure. Glad you were able to bring it to another shop that knows what they're doing to correct the mistakes. You should post up the name of the shop so everyone knows to avoid them IMHO.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
![]() ![]() Drives: 10 ABM 1SS/00 Z28 Conv/14 SumWh 2LT Join Date: Apr 2009
Man you've had some crappy luck with people working on your car.
![]() Drives: 427 Join Date: Jan 2010
Wow that's horrible, I bet I can guess who did that...
check out @LSX_CANADA on Instagram.
#6 |
![]() Drives: 2014 yellow 2SS/RS Join Date: Apr 2015
Glad you got it all fixed up properly.
K&N, Borla ATAK axle back, resonator delete, Speed Engineering headers,Vitesse, Zl1 wheels, ACS rocker panels, 1LE splitter
#7 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
#8 |
[QUOTE=3rdgen3;9718184]Always install o2 bungs at an upwards angle preferably 15* or so or else you'll experience premature sensor failure.
QUOTE] Unfortunately it looks like it is still at the wrong angle because its in the header collector. You can see this in the 10th picture (2nd of the finished ones)
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
#9 | |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
MO6 posted a thread on CCFBG. I pm'd you the link.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
#10 |
Oh I agree %100 but if we post names all of a sudden our posts get deleted.
#11 |
![]() Drives: 2010 Camaro Join Date: Oct 2015
But first, the business owner comes on and belittles people, calls them names, accuses people of making up stories and pictures, etc. or says he was not given an opportunity to defend himself and the work done...I wonder how he would defend this work??
#12 |
What I want to no is, how are people supposed to make educated choices of shops to use when the bad reviews get deleted on a forum that is used to help its members? Good or bad they should be visible to help, especially when you can see how the owners explode
#13 |
![]() How they handle it....... |
#14 | |
![]() Drives: 2009 Cadillac CTS-V Join Date: Oct 2015
